Wkid override in print task
1644
02-07-2013 05:27 PM
KellyChan
We're using Non-Esri wms services in our map. All works fine but the Print widget fails.
The web map definition sent to the print utility only shows wkid: 102100 instead of the "official" 3857. We need to use that override in the wms layer tag.
How do we get the print widget to send 3857?
DasaPaddock
Try setting wkid="3857" on the map tag in your config.xml. This will set the spatial reference of the map to 3857 which should then be used in the export web map request.
Reference:
http://resources.arcgis.com/en/help/flex-viewer/concepts/index.html#/Main_configuration_file/01m3000...
