Widget Problem
1089
10-18-2011 10:28 AM
MichaelZierten
When I try to add Robert Scheitlin's eSearch widget to my flexviewer, I get the following error:
Error #1006: addListener is not a function.
I've had this problem with a few other widgets as well.
I'm running V2.4 of FlexViewer.
TIA
Mike Zierten, NDWR
RobertScheitlin__GISP
Mike,
   You need to post FlexViewer and Widget Questions to the Flex Viewer forum:
http://forums.arcgis.com/forums/111-ArcGIS-Viewer-for-Flex
If you are really running Flex Viewer 2.4 than you would not get this error... Has your version of Flex Viewer been modified?
MichaelZierten
Mike,
OOPS! Sorry, I didn't see the FlexViewer and Widget forums.
I thought It might be an issue with the flex version, but I'm pretty sure I upgrade to 2.4. I'll download it again and try it.
Thanks.
MichaelZierten
Thanks.
That was it. I thought I had updated it, but I overwrote it with the earlier version. Thanks.
