Widget Minimize Behavior
1544
07-06-2011 01:01 PM
WadeGivens
Been pouring over the forums today looking for this to no avail.  How do you change a widget's minimize behavior?  I noticed some widgets when you minimize will collapse to the upper-right or upper-left.  When buiding your own widget how can you control this behavior (or control it for an existing widget).
Wade
RobertScheitlin__GISP
Wade,
  Don't forget that Flex Viewer questions should be posted to the flex viewer forum.
http://forums.arcgis.com/forums/111-ArcGIS-Viewer-for-Flex
The answer is that the widgets transition are controlled in the WidgetTemplateSkin.mxml under the com.esri.viewer.skins folder. You can create your own WidgetTemplateSkin if you wish.
WadeGivens
Wade,
Thanks againg Robert!
Forgot which forum I was in...
