What does the query widget query?
3154
17
12-09-2010 12:34 PM
RichardHolloway
I am new and trying to figure this out.  You query a service but how do I create the items to be queried within that service?  In ArcMap I can't seem to find what I am looking for.  Can someone point me in the correct direction?
RobertScheitlin__GISP
Richard,
   The Flex API and the FlexViewer are built around the ability to consume the REST EndPoint of ArcGIS Server.
So the query widget querys a MapService (through the REST EndPoint) that is published on ArcGIS Server.
Here is a link about publishing MXDs to ArcGIS Server.
http://help.arcgis.com/en/arcgisserver/10.0/help/arcgis_server_dotnet_help/index.html#/Tutorial_Publ...
RichardHolloway
Yep, got that but in the query widget don't you have to set something on the layer of the webservice for it to query?  Or am I not understanding it.
RichardHolloway
Is this what I need to look at?  Geodatabase: Working with Standard Spatial Datasets
Richard,
   No you don't have to do anything if you except all the defaults and make sure that you don't have the shape or objectid fields of any layer in the mxd that you want to search.
Richard,
   Are you just trying to get your head wrapped around this or are you actually having issues querying one of your published map services?
RichardHolloway
LOL...getting my head wrapped around it.  I am looking at the example in for the police depts on the query widget.  I see the xml and all that but just don't see how to populate the items to be selected in the widget nor how does it select the items.  What is it querying and how are the items set up to query in the layer.  Does that make sense?  All I see is the query in the xml and a result.  No in between configuration.
RichardHolloway
Richard,
   Maybe you should begin here with a simple sample of using the query task
http://help.arcgis.com/en/webapi/flex/samples/index.html?sample=QueryTaskOnMap
Richard,
   Also based on this statement
it sounds like you are not using the FlexViewer source code. DO you have FlashBuilder?
