What determines display order of layers?
1065
05-02-2011 06:38 AM
WaltBulawa
On my map I have two graphics layers (one for queried polygons and one for Identify Results) and a ArcGISDynamicMapServiceLayer (for parcels).
My problem is that the parcel layer appears on top of the IdentifyResults layer, which I would rather be on top.  I tried to move it on top with the following:
clickGraphicsLayer.moveToTop(clickGraphic);
clickGraphic.symbol = new InfoSymbol(); // use default renderer
clickGraphic.attributes = resultGraphic.attributes;
but, alas, it seems to have no effect --- the parcels still appear on top of the resultsGarphic.
Is there a way to make this specific layer appear on top of all the others?
DasaPaddock
The order of the layers inside the Map are reflected by the order of the layers in the ArrayCollection exposed by the "layers" property:
http://help.arcgis.com/en/webapi/flex/apiref/com/esri/ags/Map.html#layers
You can manipulate this ArrayCollection directly or call reorderLayer()
http://help.arcgis.com/en/webapi/flex/apiref/com/esri/ags/Map.html#reorderLayer()
You can also choose where a layer is added by passing the position to addLayer()
http://help.arcgis.com/en/webapi/flex/apiref/com/esri/ags/Map.html#addLayer()
