Weather Underground Widget for FlexViewer 2.1
5996
17
09-23-2010 08:12 PM
RobertScheitlin__GISP
All,
I have been waiting for the Final release of the FlexViewer 2.1 before I started to push out some widgets I have been working on.
Here is my Weather Underground widget
http://www.arcgis.com/home/item.html?id=f6bf35d7e7dc4db697f9718fd1b2b53f#
More FlexViewer 2.1 widgets to come stay tuned...
MattMoyles
Awesome! I'm looking forward to seeing other widgets you have come up with.
EjayLai
I wanted to take use of it but Weather Underground doesn't seem to have much stations in Ontario, does it?
YiJia,
   Type in "London, Canada" or a conadian airport code like YGK
All,
   New version Available.
PaulHeinrich
Robert,
Thanks for the useful Widget!  If you continue to develop it, it might be neat to include the ability to use several fixed locations instead of a search or single default search.
cheers,  Paul
EjayLai
YiJia,
Thanks Robert. It does bring me to London if I type in a small town nearby such Simcoe, Ontario. If will be great if the Weather network has Flex API available, which provides more stations.
DanielMunoz
Excellent! thank you. have you ever consider the ability to overlay the radar image and/or weather warnings on the map?
ChristinaMcCullough
I love this widget.  I have had the Weather Underground widget on my viewer for some time, but now I am getting this error.
[IOErrorEvent type="ioError" bubbles=false cancelable=false eventPhase=2 text="Error #2032"]
Fault code: Server.Error.Request
Fault info: HTTP request error
Fault details: Error: [IOErrorEvent type="ioError" bubbles=false cancelable=false eventPhase=2 text="Error #2032"]. URL: http://mccullough-consulting.net/Working/widgets/WeatherUnderground/WUndergroundWidget.xml
http://mccullough-consulting.net/Working/index.html
Christina,
  Your xml file http://mccullough-consulting.net/Working/widgets/WeatherUnderground/WUndergroundWidget.xml is not there/available any more did it somehow get deleted?
