View attachments in pop-up window
1932
06-26-2011 01:21 PM
alexGole2
Does anyone have any idea how to create a widget that shows ArcSDE attachments within a pop-up window?
Alex
alexGole2
http://forums.arcgis.com/threads/24574-FlexViewer-SDE-Attachments?highlight=ArcSDE+attachments
I downloaded this widget but where do I plug-in my JPG ArcSDE attachments. It does not see any of my attachments. Does it work with a feature service?
Jere is my XML:
<?xml version="1.0" ?>
<configuration>
<fields>URL,OBJECTID,ONLINE,DESCRIPTION,LAST_UPDATED</fields>
    <titlefield>DESCRIPTION</titlefield>
    <links>
     <linkfield icon_or_text_or_img="img" icon=""
          linkalias="" linkprefix="" linksuffix="">http://664-05/ArcGIS/rest/services/Feature/FeatureServer/0/1</linkfield>
     <linkfield icon_or_text_or_img="text" icon=""
          linkalias="Show Image..." linkprefix="" linksuffix="">http://664-05/ArcGIS/rest/services/skidooalex/MapServer/0</linkfield>
     <linkfield icon_or_text_or_img="icon" icon="assets/images/i_lego.png"
          linkalias="Show Image..." linkprefix="" linksuffix="">http://664-05/ArcGIS/rest/services/Feature/FeatureServer/0/2</linkfield>
     <linkfield icon_or_text_or_img="icon" icon="assets/images/i_camera.png"
     <linkfield icon_or_text_or_img="icon" icon="assets/images/i_clock.png"
          linkalias="Show Image..." linkprefix="" linksuffix="">ONLINE</linkfield>
     <linkfield icon_or_text_or_img="icon" icon="assets/images/i_about.png"
    </links>
    <multiimagefield linkprefix="" linksuffix="" nexttooltip="Next" prevtooltip="Prev"></multiimagefield>
    <layername>SkidooChange</layername>
    <datefields>LAST_UPDATED</datefields>
    <zoomscale>5000</zoomscale>
    <csvseparator>,</csvseparator>
    <labels>
     <csvdefaultname>Related Records</csvdefaultname>
  <exportbtnlabel>Export...</exportbtnlabel>
  <export2csvoptionlabel>Export to CSV...</export2csvoptionlabel>
  <export2txtoptionlabel>Export to Txt...</export2txtoptionlabel>
    </labels>
</configuration>
Alex
RobertScheitlin__GISP
Alex,
  I provide a pretty detailed pdf that covers how to configure this widget. Have you looked at it. Is "SkidooChange" the way you have your layer labeled in your main config.xml?
alexGole2
Alex,
Yes, I have. Here is my main config file:
<configuration>
    <title>ArcGIS Viewer for Flex</title>
    <subtitle>a configurable web mapping application</subtitle>
    <style>
        <!-- Black Gold -->
        <colors>0xFFFFFF,0x333333,0x101010,0x000000,0xFFD700</colors>
    </style>
    <!-- replace the following url with your own geometryservice -->
    <geometryservice url="http://tasks.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer" />
    <!-- replace the following key with your own Bing key -->
    <bing key="Ahw1due6dkmZg98wUJJYLrVmYlDik4oleCg6hoNqx6l2jFYRToImQH1HfH-asjjH"/>
    <splashpage label="ArcGIS Viewer for Flex" config="widgets/Splash/SplashWidget.xml" url="widgets/Splash/SplashWidget.swf"/>
    <widget left="10" top="50" config="widgets/Navigation/NavigationWidget.xml" url="widgets/Navigation/NavigationWidget.swf"/>
    <widget bottom="35" right="5" config="widgets/StaticImage/StaticImageWidget.xml" url="widgets/StaticImage/StaticImageWidget.swf"/>
    <widget right="-2" bottom="-2" config="widgets/OverviewMap/OverviewMapWidget.xml" url="widgets/OverviewMap/OverviewMapWidget.swf"/>
    <widget right="15" top="55" config="widgets/MapSwitcher/MapSwitcherWidget.xml" url="widgets/MapSwitcher/MapSwitcherWidget.swf"/>
    <widget left="0" top="0" config="widgets/HeaderController/HeaderControllerWidget.xml" url="widgets/HeaderController/HeaderControllerWidget.swf"/>
    <widget left="3" bottom="3" config="widgets/Coordinate/CoordinateWidget.xml" url="widgets/Coordinate/CoordinateWidget.swf"/>
    <map wraparound180="true" initialextent="-14083000 3139000 -10879000 5458000" fullextent="-20000000 -20000000 20000000 20000000" top="40">
        <basemaps>
            <layer label="Streets" type="tiled" visible="true"
                   url="http://server.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer"/>
            <layer label="Aerial"  type="tiled" visible="false"
                   url="http://server.arcgisonline.com/ArcGIS/rest/services/World_Imagery/MapServer"/>
            <layer label="Topo"    type="tiled" visible="false"
                   url="http://server.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer"/>
        </basemaps>
    <operationallayers>
         <layer label="SkidooChange" type="feature" visible="true" alpha="1"
             info="widgets/InfoTemplates/AttRelateInfoWinWidget.swf"
             infoconfig="widgets/InfoTemplates/SkidooChange.xml"
             url="http://664-05/ArcGIS/rest/services/skidoo/MapServer/0"/>
     </operationallayers>
    </map>
    <widgetcontainer layout="horizontal"> <!--horizontal(default)|float|vertical|fix-->
        <widget label="Query Widget"
            icon="assets/images/i_attachment.png"
            config="widgets/Query/QueryWidget.xml"
            url="widgets/Query/QueryWidget.swf"/>
        <widget label="Bookmarks"
            icon="assets/images/i_bookmark.png"
            config="widgets/Bookmark/BookmarkWidget.xml"
            url="widgets/Bookmark/BookmarkWidget.swf"/>
        <widget label="Draw and Measure"
            icon="assets/images/i_draw2.png"
            config="widgets/Draw/DrawWidget.xml"
            url="widgets/Draw/DrawWidget.swf"/>
        <widget label="Earthquakes (GeoRSS)"
            icon="assets/images/i_rss.png"
            config="widgets/GeoRSS/GeoRSSWidget.xml"
            url="widgets/GeoRSS/GeoRSSWidget.swf"/>
    </widgetcontainer>
</configuration>
Config ITW_Camera:
<configuration>
<fields>http://664-05/ArcGIS/rest/services/Feature/FeatureServer/0/1,1,ONLINE,DESCRIPTION,LAST_UPDATED</fields>
    <titlefield>SkidooChange</titlefield>
    <links>
    </links>
    <labels>
    </labels>
</configuration>
Thanks for your help,
PS: I am reading your documentation (very well done) but still does not work... What am I doing wrong?
Alex,
  What in the world is this stuff you have where field names should be?...
<configuration>
    <links>
                   linkalias="Show Image..." linkprefix="" linksuffix="">ONLINE (do you have a field called this in your layer?)</linkfield>
    </links>
    <datefields>LAST_UPDATED (do you have a field called this in your layer?)</datefields>
    <labels>
    </labels>
</configuration>
