Vertical Scrollbar disabled
3924
01-20-2012 03:58 AM
DebbieAlger
I have a vertical scrollbar showing up in the right place, but it is disabled, kind of a tease!
this is how I have it set up..
<s:BorderContainer width="100%" height="100%"   borderVisible="false" backgroundAlpha="0"   >
   <mx:Form borderVisible="true"  top="0"  bottom="0" left="0" height="100%" width="100%" >
<mx:VBox height="100%"   width="100%"   verticalScrollPosition="{this.width }"   verticalScrollPolicy="on"  >
blah, blah....
    </mx:VBox>
  </mx:Form>
</s:BorderContainer>
thanks,
RobertScheitlin__GISP
Debbie,
   Are you actually using mx formItems in your form or are you just using it as a container for some reason?
Debbie,
   It is can of hard to say without knowing the whole context of your code but you likely need to set an explicite width not 100%
   <mx:Form borderVisible="true"  top="0"  bottom="0" left="0" width="300" >
blah, blah....
    </mx:VBox>
  </mx:Form>
Also you should get use to not using a VBox and start using a VGroup now, and if you are building against the Flex SDK 4.5.1 or higher than you should also be using spark form component and not mx form anymore.
DebbieAlger
thanks, but no that isn't it. The weird thing is that I use a vertical scrollbar in a VBox embedded lower and it works fine.
But I appreciate the info on changing over to spark components..
Debbie,
DebbieAlger
I'm not using them at all, maybe I shouldn't?? Sorry, this is my first Flex app, kinda going by the seat of my pants..
this is all the actionscript for it..
   <!--================== STEP 1 BOX ======================-->
   <mx:VBox width="100%" height="25%"    paddingLeft="5"  paddingRight="5" paddingTop="2"  borderStyle="solid" borderVisible="true"   verticalGap="0" horizontalAlign="left"     >
       <mx:Text id="Step1"   text="{resourceManager.getString('resources', 'step1')}"  width="150" textAlign="left" fontWeight="bold"/>
    <mx:HBox>
         <mx:Text  text="{resourceManager.getString('resources', 'enterWatershedName')}" paddingLeft="5"  paddingRight="10" paddingBottom="5"   />
         <s:TextInput id="watershedName"  enabled="true"     change="{setupTool()}"  />
    </mx:HBox>
   </mx:VBox>
   <!--============== STEP 2 BOX ===================-->
   <mx:VBox width="100%" height="100%"    paddingLeft="5"  paddingRight="5" paddingTop="2"  borderStyle="solid" borderVisible="true"   verticalGap="0" horizontalAlign="left"     >
      <mx:Text id="Step2"   text="{resourceManager.getString('resources', 'step2')}"  width="150" textAlign="left" fontWeight="bold"/>
    <s:HGroup   paddingTop="5"  paddingLeft="5" verticalAlign="middle" >
     <mx:Text id="txtLabel"   text="{resourceManager.getString('resources', 'mapClick')}"  width="150" textAlign="left"/>
     <mx:Button click="{verifyTool()}"  id="wsButton"
          upSkin="@Embed('assets/images/icons/i_hydro.png')"
          overSkin="@Embed('assets/images/i_hydro_selected2.PNG')"
          downSkin="@Embed('assets/images/i_hydro_selected2.PNG')"
          disabledSkin="@Embed('assets/images/i_hydro_disabled.png')"
          enabled="false"  buttonMode="true"   useHandCursor="true"  paddingBottom="5"  width="25" height="25"  />
    </s:HGroup>
    <mx:HBox   horizontalAlign="left"  width="100%"  verticalAlign="middle" >
     <mx:Text  paddingLeft="5"  text="{resourceManager.getString('resources', 'scale1')}"  styleName="WidgetText"  />
    </mx:HBox>
    <mx:HBox horizontalAlign="left" paddingLeft="5" width="100%" verticalAlign="middle">
     <mx:Text   text="{resourceManager.getString('resources', 'scale2')}"  styleName="WidgetText" />
     <mx:Text  id="txtScale"  text=""   styleName="WidgetText" />
    </mx:HBox>
   <mx:VBox width="100%"   paddingTop="5"   verticalGap="0" horizontalAlign="center"     >
    <mx:Text id="txtOr" text="{resourceManager.getString('resources', 'or')}" fontWeight="bold"  width="100%" textAlign="center"/>
   </mx:VBox>
   <!--  ====== LAT & LONG  ========== -->
   <mx:HBox width="90%"  paddingLeft="5"  paddingRight="5"  paddingTop="10"  paddingBottom="10" >
    <mx:Text   text="{resourceManager.getString('resources', 'enterLat')}  " />
    <s:TextInput    width="95"     id="txtLat" text="45.304024" textAlign="right" />
   </mx:HBox>
   <mx:HBox  paddingLeft="5">
           <mx:Text  text="{resourceManager.getString('resources', 'enterLong')}" />
    <s:TextInput   width="95"   id="txtLong" text="-75.848191" textAlign="right"  />
   </mx:HBox>
   <s:HGroup  paddingLeft="95" paddingBottom="5" paddingTop="5">
     <s:Button    id="btnSubmit"  buttonMode="true"   useHandCursor="true"     click="createPoint()"  enabled="{watershedName.text.length >0 &amp;&amp;  txtLat.text.length >0  &amp;&amp;  txtLong.text.length >0 }"  color="0x000000" label="{resourceManager.getString('resources', 'submit')}" width="70"  />
   </s:HGroup>
    </mx:VBox>
   <!-- ==== DATAGRID with Watershed Info, invisible if nothing created   wRepeater.currentIndex,wRepeater.currentItem.wsName   visible="{wsArray !=null &amp;&amp; wsArray.length>0}"  -->
   <mx:Box  width="100%" height="100%"   paddingLeft="10" styleName="WidgetText"    horizontalScrollPolicy="off"  borderStyle="solid" borderVisible="true"   visible="{wsArray !=null &amp;&amp; wsArray.length>0}" >
    <s:Label    text=" "  />
    <s:Label id="txtDG"    paddingLeft="5" fontWeight="bold" text="{resourceManager.getString('resources', 'results')}"   />
    <s:Label id="txtHeading"     paddingLeft="5"  text="{resourceManager.getString('resources', 'dgHeading')}  "     />
    <mx:Canvas  width="100%"     >
     <!-- 325 -->
     <mx:VBox height="150"  width="100%" horizontalScrollPolicy="off"   verticalScrollPosition="{this.width }" verticalScrollPolicy="auto"  >
      <mx:Repeater  dataProvider="{wsArray}"  id="wRepeater"   >
       <mx:HBox    >
        <mx:Button click="remove(event )" buttonMode="true"   useHandCursor="true"   toolTip="{resourceManager.getString('resources', 'deleteWS')}"
             upSkin="@Embed('assets/images/delete.png')"
             overSkin="@Embed('assets/images/delete_selected.png')"
             downSkin="@Embed('assets/images/delete_selected.png')"  width="20" height="20"  />
        <mx:Button click="Export(event )" buttonMode="true"   useHandCursor="true"  toolTip="{resourceManager.getString('resources', 'exportWS')}"
             upSkin="@Embed('assets/images/export.PNG')"
             overSkin="@Embed('assets/images/export_selected.JPG')"
             downSkin="@Embed('assets/images/export_selected.JPG')"  width="20" height="20"  />
        <s:Label   text="{wRepeater.currentItem.wsName}"  buttonMode="true"  useHandCursor="true" color="#0000FF" textDecoration="underline" fontSize="14" styleName="WidgetText"  toolTip="{resourceManager.getString('resources', 'zoomWS')}"  click="zoomLocation(event)"      />
       </mx:HBox>
       <mx:HBox>
        <mx:Image  id="showCharacterize" click="btnShowCharacterize(event)"  buttonMode="true"  useHandCursor="true"   toolTip="{resourceManager.getString('resources', 'expand')}" source="{plusSign}"  width="15" height="15"    />
        <s:Label   fontWeight="bold" text="{resourceManager.getString('resources', 'characterize')}"  styleName="WidgetText"   visible="true"  />
       </mx:HBox>
       <!-- Datagrid of created watersheds -->
       <mx:VBox id="displayDatagrid"    paddingLeft="10"  height="0" visible="false" >
        <mx:DataGrid id="datagrid" dataProvider="{wRepeater.currentItem.gridData}"   rowCount="5" styleName="WidgetText" itemClick="dgClick(event)"   >
         <mx:columns>
          <mx:DataGridColumn headerText="Characterization"    dataField="charType" width="125"/>
          <mx:DataGridColumn headerText="Value"    dataField="charValue" width="75"/>
          <mx:DataGridColumn headerText="Select"   dataField="charChkBox" width="50"    itemRenderer="mx.controls.CheckBox" />
         </mx:columns>
        </mx:DataGrid>
        <mx:Button   id="btnCharacterize"  paddingLeft="10"   click="characterize(event)"   label="{resourceManager.getString('resources', 'selectChars')}" width="250"  />
       </mx:VBox>
      </mx:Repeater>
     </mx:VBox>
    </mx:Canvas>
   </mx:Box>
  </mx:Form>
DebbieAlger
actually, Robert, I don't want to waste your time, we have decided not to worry item. I just have the outstanding item in my other scrollbar post regarding the resizing of the window.
thanks for your input on this question.
