UTM or State Plane to Decimal Degrees
3240
10-11-2010 03:08 PM
FrankRoberts
FlexAPI 2.1 Question:
Does anyone have some code that they could share to convert coordinates (for example a single mappoint) from State Plane/and or UTM to decimal degrees (i.e. wkid 4326)?  The Web Mercator utilities are great for doing this on the client side, but unfortunately not all of my services are in Web Mercator.
I imagine this require a trip back and forth between the server.  I just  haven't found a sample of that yet.
Thanks for your help!
Frank
Code currently looks as follows:
const mapPoint:MapPoint = map.toMapFromStage(event.stageX, event.stageY);
var latlong:MapPoint;
var wkidString:String = mapPoint.spatialReference.wkid.toString();
//Alert.show(mapPoint.spatialReference.wkid.toString());
if ( wkidString == "102100")
latlong = WebMercatorUtil.webMercatorToGeographic(mapPoint) as MapPoint;
else if ( wkidString == "3857")
else if ( wkidString == "4326")
latlong = map.toMapFromStage(event.stageX, event.stageY);
else
Alert.show("This widget will not work with data in this projection");
frLat = latlong.y.toFixed(6);
frLong = latlong.x.toFixed(6);
RobertScheitlin__GISP
JacksonTrappett
If you're looking to avoid the trip to and from the server you can always do the math in the client, check out this thread for a sample function:
http://forums.arcgis.com/threads/1786-Flex-Display-latitude-and-longitue
It's a little more complicated but works better for things where you have a lot of calls to the function, like showing the mouse location in lat long as the user moves the mouse around.  If you're just doing a single point at a time though, its easier to have the server do the reproject like in Robert's example.
FrankRoberts
Thanks to both of you, the ESRI sample Robert pointed me to was useful.  My question is there anyway to avoid adding the Declarations section at the end (i.e. just define the geometryService info in the body of the Action Script function)??
Hope this helps someone!
Frank
The code below is what I ended up doing, please note the goal hear was to pass lat and long to a function called "displayForm" :
private function mouseClickHandler(event:MouseEvent):void
const frmapPoint:MapPoint = map.toMapFromStage(event.stageX, event.stageY);
var wkidString:String = frmapPoint.spatialReference.wkid.toString();
//Alert.show("Spatial Ref for map: " + frmapPoint.spatialReference.wkid.toString());
  latlong = WebMercatorUtil.webMercatorToGeographic(frmapPoint) as MapPoint;
  displayForm(frLat, frLong);
else
  //Alert.show("Non client side projection");
  var outSR:SpatialReference = new SpatialReference(4326);
  geometryService.project([frmapPoint as Geometry], outSR);
var graphic:Graphic = new Graphic();
var mapPoint2:MapPoint = frmapPoint;
mapPoint2.spatialReference = map.spatialReference;
graphic.geometry = mapPoint2;
graphicsLayer.clear();
graphicsLayer.add(graphic);
//private var infoWindowText:String;
private function projectCompleteHandler(event:GeometryServiceEvent):void
try
  // Note: As of version 2.0, GeometryService returns geometries (instead of graphics)
  var pt:MapPoint = (event.result as Array)[0]as MapPoint;
  //Alert.show(pt.x + ", " + pt.y);
  displayForm(pt.y.toString(),pt.x.toString());
catch (error:Error)
  Alert.show(error.toString());
I then had to add this after the Script Tags, as to identify the server and projectComplete event:
<fx:Declarations>
<esri:GeometryService id="geometryService"
   concurrency="last"
   fault="onFault(event)"
   projectComplete="projectCompleteHandler(event)"
   url="http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer"/>
</fx:Declarations>
