using python script in flex
3258
01-16-2013 01:37 AM
NadeemQazi
I have used Near Table Analysis tool in ARc map using Python script. it works well. however now i want to use this tool from my browser. I am using flash builder along with ArcGIS API for Flex 3.0. any suggestion how to use the python scripted  queries from flex environment.
regards
nadeem
IvanBespalov
Nadeem,
Geoprocessing tasks in ArcGIS API for Flex concepts
Geprocessor tasks in ArcGIS API for Flex samples
Publishing a geoprocessing service in ArcGIS Desktop help
Geoprocessing service in ArcGIS Server REST API help
NadeemQazi
Nadeem,
Publishing a geoprocessing service in ArcGIS Server help
Thank you ,. I got the idea.  I am planning to make this script as tool and than publish this tool as service Task on ARCGIS server and than access it from the client. However i have one more query and it is suppose i want that when user clicks a point in the map than i want to take this information and pass it to the query. I have a layer on the map named Tanks. This Tanks layers has associated   attribute table having FID and other attributes. What I want is that when i click on any tank on the map i can retrieve the FID of the selected tank and can pass it to my python script. any suggestion is appreciate. Thank you in advance.
