using Locale languages
2080
7
01-09-2012 10:07 AM
DebbieAlger
I am having difficulty adding my own set of strings in english and french. I have followed the instructions, added the 2 folders and resource files, then I
changed the Properties -> Compiler -> arguments to
-locale=en_CA,fr_FR -source-path=locale/{locale}
But, it then gives me 1,000's of errors like unable to resolve resource bundle "blah blah". I can guess that this is because it wants the en_US swc file strings in the  "Program Files\Adobe\Adobe Flash Builder 4\sdks\4.1.0\frameworks\locale" folder. But, how do I set this up. it seems that my new files override everything.
ideas?? I know this has been done tons of times by others.
thanks,
DasaPaddock
Yes, if you use en_US than you won't have to run the copylocale tool. If you use a locale that isn't included in the Flex SDK, it doesn't know where to get the bundles needed by the SDK unless you create them.
RobertScheitlin__GISP
Debbie,
  Try removing the equal sign:
-locale en_CA,fr_FR -source-path=locale/{locale}
AndyGup
If you compile with additional languages I believe you do need the "=" sign after locale. You might also give this a try by adding the keep all type selectors property: -locale=en_CA,fr_FR -source-path=locale/{locale} -keep-all-type-selectors=true
DebbieAlger
Thanks for your speedy replies,
I tried  the remove equal sign and got these errors..
    unable to open 'locale/en_CA,fr_FR'
I tried the -keep-all-type-selectors=true and got 1,000's of these errors...
    Unable to resolve resource bundle "charts".
I don't see why this is so confusing, this must be done all the time???
DasaPaddock
The Flex SDK doesn't have a en_CA locale. Try using using only the fr_FR locale and see if it compiles. If you want both, you'll need to run the SDK\4.1.0\bin\copylocale en_US en_CA
See:
http://help.adobe.com/en_US/flex/using/WS2db454920e96a9e51e63e3d11c0bf69084-7f2d.html#WS2db454920e96...
DebbieAlger
Thanks for reply Dasa,
I am confused even more then. I thot by adding my own file (en_CA) under the locale folder, then that info would be used for my translations. Does this
mean that I should've named my file en_US, I really don't care what it is named. I still want the framework translations to be used for every other item that I don't include.
thanks,
DasaPaddock
DebbieAlger
Thanks so much Dasa,
I was making things way more difficult than I had to. I didn't realize that the new locale had to have an exact match in the SDK/frameworks/locale folder. I didn't care if it was called CA or US. I feel silly, it is quite simple.
THanks for you patience.
