Using Flex query a layer by field other than display field.
2613
10
07-06-2010 09:57 AM
PaulLang
ArcGIS Server 9.3.1 Flex 1.3
How can you query fields other than the Display Field:
Drew
Paul,
See this sample to query your features table.
http://resources.esri.com/help/9.3/arcgisserver/apis/flex/samples/index.html?sample=QueryTaskNoMap
EDIT: Then add the "where" clause as outlined in the docs.
http://resources.esri.com/help/9.3/arcgisserver/apis/flex/apiref/com/esri/ags/tasks/Query.html
You can view all the ESRI Flex 1.3 samples here if you wish to explore further.
SreeS
You can query any field that you want. It need not be the Primary display field.
It depends on what expression you are feeding your "query.where".
PaulLang
private function doQuery():void
         queryTask.execute(query, new AsyncResponder( onResult, onFault));
            function onResult(featureSet:FeatureSet, token:Object = null):void
             var unionExtent:Extent;
                var myFirstGraphic:Graphic = featureSet.features[0];
                //dataApp.visible = true;
                unionExtent = Polygon(myFirstGraphic.geometry).extent;
                MainMap.extent = unionExtent;
                myFirstGraphic.toolTip = "AKPAR: " + myFirstGraphic.attributes.AKPAR + "\n" + "Current Owner: " + myFirstGraphic.attributes.CURR_NAME1 + "\n" + "Current Owner: " + myFirstGraphic.attributes.CURR_NAME2 + "\n" + "Address: " + myFirstGraphic.attributes.CURR_ADDR1  ;
             dpFlat.push(dataGrid1.dataProvider.toString());
            function onFault(info:Object, token:Object = null):void
                Alert.show(info.toString());
<esri:QueryTask id="queryTask" url="http://egov3/ArcGIS/rest/services/Testing/Dynamic/MapServer/0/" />
     <esri:Query id="query" text="{qText.text}" returnGeometry="true">
         <esri:outFields>
          <mx:String>DISTHIGH</mx:String>
             <mx:String>DISTMIDDLE</mx:String>
             <mx:String>DISTELEMEN</mx:String>
             <mx:String>HOUSENO</mx:String>
             <mx:String>POSTAL</mx:String>
             <mx:String>STATE</mx:String>
             <mx:String>ZIP</mx:String>
             <mx:String>JURISDICT</mx:String>
             <mx:String>FULLNAME</mx:String>
             <mx:String>AKPAR</mx:String>
        </esri:outFields>
    </esri:Query>
Drew
<esri:Query
id="query"
where="STATE_NAME='Carolina'"
outFields='["STATE_NAME","STATE_FIPS","SUB_REGION","STATE_ABBR","POP2000","POP2007"]'/>
PaulLang
Works when I hard code the value.
How can I change the where to use qTextAdd.text, value enter by user?
Drew
Like so..
<esri:Query
id="query"
returnGeometry="false"
where="STATE_NAME = '{qTextAdd.text}'"
PaulLang
I tried that before my last response, but it does not work.   Do I need to bind the value?
Drew
works for me..
here is a full application you can test that is derived form the ESRI samples.
<?xml version="1.0" encoding="utf-8"?>
<mx:Application
    xmlns:mx="http://www.adobe.com/2006/mxml"
    xmlns:esri="http://www.esri.com/2008/ags"
    pageTitle="Query Task (without a map)">
    Problem:
        How to query the server?
    Solution:
        Send the query using the execute() method on a QueryTask.
    This sample sets up a QueryTask (what layer on what server to query).
    When user clicks the "Get Details" button, a Query is sent with the
    user-provided text to search for.
    Meanwhile a DataGrid has been setup and listens for the results
    (using executeLastResult) from the querytask.
    <!-- Start Declarations -->
        <esri:QueryTask
            id="queryTask"
            url="http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer/5"/>
        <esri:Query
            id="query"
            where="STATE_NAME = '{stateName.text}'"
    <!-- End Declarations -->
    <mx:Panel title="Using Query tasks without maps">
        <mx:HBox>
            <mx:Label text="US state name: " />
            <mx:TextInput id="stateName" text="Colorado" />
            <mx:Button label="Get Details" click="queryTask.execute(query);" />
        </mx:HBox>
        <mx:DataGrid id="resultsGrid" dataProvider="{queryTask.executeLastResult.attributes}" visible="{queryTask.executeLastResult != null}" >
            <mx:columns>
                <mx:DataGridColumn headerText="State Name" dataField="STATE_NAME"/>
                <mx:DataGridColumn headerText="Region" dataField="SUB_REGION"/>
                <mx:DataGridColumn headerText="FIPS" dataField="STATE_FIPS"/>
                <mx:DataGridColumn headerText="Abbreviation" dataField="STATE_ABBR"/>
                <mx:DataGridColumn headerText="Population 2000" dataField="POP2000"/>
                <mx:DataGridColumn headerText="Population 2007" dataField="POP2007"/>
            </mx:columns>
        </mx:DataGrid>
     </mx:Panel>
</mx:Application>
PaulLang
Must be something to do with the data type of field FULLNAME, because I changed to ZIP and it works fine.
