Use attributeInspector to create new entity
3764
03-12-2014 08:02 AM
MathieuVILLEMONT1
I would like to use the attributeInspector to create a new entity in a layer/table.
This attributeInspector would be placed in a pop-up or outside the map.
So far I was thinking to do something like this:
var attrInspector:AttributeInspector  = new AttributeInspector(); ... attrInspector.featureLayers = [featLayer]; var g:Graphic = new Graphic(); attrInspector.showFeature(g, featLayer);
Is it a good approach ?
Thanks.
MathieuVILLEMONT1
Update :
I have tried to add it to the InfoWindow :
var attr:AttributeInspector  = new AttributeInspector(); attr.featureLayers = [featLayer]; var g:Graphic = new Graphic(); var attributes:Object = {}; attributes["OBJECTID"] = ""; g.attributes = attributes; attr.showFeature(g, featLayer); map.infoWindow.visible = true; map.infoWindow.anchorX = 15; map.infoWindow.anchorY = 200; map.infoWindow.content = attr;
but the infoWindow is displayed empty.
The problem with this was that the layer was not loaded and therefore did not have any featureDetails.
I found the solution on this thread.
Thank you Robert and Walt!
MathieuVILLEMONT1
Update :
MathieuVILLEMONT1
Update :
