Update this example from Flex API 1.3 to 2.2
4100
02-10-2011 02:48 AM
DylanRoy
I was wondering if anyone was able to update this example that uses the Flex 1.3 API to the most current version. Query no longer exists and it seems to be QueryTask's predecessor. If I get it converted I will post it in a reply.
Thanks!
<?xml version="1.0" encoding="utf-8"?>
<mx:Application
    xmlns:mx="http://www.adobe.com/2006/mxml"
    xmlns:esri="http://www.esri.com/2008/ags"
    pageTitle="Find features in Map Layers"
    styleName="plain">
    <mx:Script>
        <![CDATA[
         import com.esri.ags.events.QueryEvent;
            import com.esri.ags.Graphic;
            import com.esri.ags.events.FindEvent;
            import com.esri.ags.geometry.Geometry;
            import com.esri.ags.tasks.Query;
            import com.esri.ags.tasks.FeatureSet;
            private function doFind():void
                findTask.execute(myFindParams);
            private function findCompleteHandler(event:FindEvent):void
                myGraphicsLayer.clear();
                var graphic:Graphic;
                var query:Query = new Query();
                resultSummary.text = event.findResults.length + " State Found using Find Task";
                var resultCount:int = event.findResults.length;
                for (var i:Number = 0; i < resultCount; i++)
                 query.returnGeometry = true;
                 query.outFields = ["CITY_NAME","POP1990"];
                 query.outSpatialReference = myMap.spatialReference;
                    graphic = event.findResults.feature;
                    query.geometry = graphic.geometry;
     graphic.symbol = sfsFind;
                    myGraphicsLayer.add(graphic);
                    queryTask.execute(query);
            private function queryCompleteHandler(event:QueryEvent):void
             var fset:FeatureSet = event.featureSet;
             resultSummary.text += " and " + fset.features.length + " cities found using spatial query."
    for each (var graphic:Graphic in fset.features)
     graphic.symbol = smsFind;
     graphic.toolTip = graphic.attributes["CITY_NAME"] + " - Population: " + graphic.attributes["POP1990"]
    </mx:Script>
    <!-- Symbol for Find Result as Point -->
    <esri:SimpleMarkerSymbol id="smsFind" style="square" color="0xFFFF00" size="11" alpha="0.9">
        <esri:SimpleLineSymbol color="0x000000"/>
    </esri:SimpleMarkerSymbol>
    <!-- Symbol for Find Result as Polygon -->
    <esri:SimpleFillSymbol id="sfsFind" color="0xFFFF00" alpha="0.7"/>
    <!-- Find Task -->
    <esri:FindTask
        id="findTask"
        executeComplete="findCompleteHandler(event)"
        url="http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Specialty/ESRI_StatesCitiesRivers_USA/MapServer"
    <!-- Query Task -->
    <esri:QueryTask
     id="queryTask"
     executeComplete="queryCompleteHandler(event)"
     url="http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Specialty/ESRI_StatesCitiesRivers_USA/MapServer/0"
    <esri:FindParameters id="myFindParams"
        returnGeometry="true"
        contains="true"
        searchText="{fText.text}"
        layerIds="[2]"
        searchFields="['STATE_NAME']"
    <mx:HBox width="100%" height="40" backgroundColor="0xDDDDFF" paddingTop="10" horizontalAlign="center">
        <mx:Text text="Search for names of States:"/>
        <mx:TextInput maxWidth="400" id="fText" enter="doFind()" text="Alabama"/>
        <mx:Button label="Find" click="doFind()"/>
    </mx:HBox>
    <mx:Text id="resultSummary" height="15"/>
        <esri:Map id="myMap">
            <esri:extent>
                <esri:Extent xmin="-126" ymin="24" xmax="-67" ymax="50">
                    <esri:SpatialReference wkid="4326"/>
                </esri:Extent>
            </esri:extent>
            <esri:ArcGISDynamicMapServiceLayer
                url="http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Specialty/ESRI_StatesCitiesRivers_USA/MapServer"/>
            <esri:GraphicsLayer id="myGraphicsLayer"/>
        </esri:Map>
</mx:Application>
RobertScheitlin__GISP
Dylan,
   A little reading in the documentation will tell you that two of the import statements in this sample have changed
import com.esri.ags.tasks.supportClasses.Query;
   import com.esri.ags.FeatureSet;
Once you change the samples existing imports to the ones listed above the sample will work again.
Supporting classes in the Tasks package has moved into a subpackage com.esri.ags.tasks.supportClasses, except for FeatureSet which is now in com.esri.ags.FeatureSet.
http://help.arcgis.com/en/webapi/flex/help/content/migrating.htm
