Unable to export release build - FlexViewer
1003
12-13-2010 07:34 AM
ChrisOwen
This error is constricting my flex app to create a release build:
  Encountered errors or warnings while building project LiveMapsWidget.mxml.
    LiveMapsWidget.mxml: Source path entry, '\Inetpub\wwwroot\devFlexViewerJCDA\src\com\esri\solutions\flexviewer\nls\en_US', is a subdirectory of source path entry, '\Inetpub\wwwroot\devFlexViewerJCDA\src'
The error appears for each mxml....
RobertScheitlin__GISP
Chris,
Be sure to post FlexViewer questions to the Flex Viewer forum.
http://forums.arcgis.com/forums/111-...iewer-for-Flex
Answer:
   Ensure you have these compiler options set in your FlexViewer Projects properties by right clicking the project in the flex navigator window and choosing properties, then switch to the "Flex Compiler" settings and look for "Additional Compiler Arguments"
-locale en_US  -allow-source-path-overlap=true
ChrisOwen
Robert,
That was it - thanks so much.
I thought I was posting in the correct location, but I will be sure to verify next time.
Best,
Chris
