TypeError: Error #1034: Type Coercion failed: cannot convert views::AGISHomeView@6396ae1 to spark.components.View.
9083
10
08-28-2014 12:11 AM
HaniDraidi
Hello all,
I am new to flex, and Flash builder, I followed the tutorial in this link: https://developers.arcgis.com/flex/guide/tutorial-query-your-data.htm to write a mobile mapping application that includes a query task, after writing the code, no errors appeared in the problems tab but there was 6 warnings, and when running the app the following error appears (Also shown in screenshots):
An ActionScript error has occurred:
            at spark.components::ViewNavigator/createViewInstance()
            at spark.components::ViewNavigator/commitNavigatorAction()
            at spark.components::ViewNavigator/commitProperties()
            at mx.core::UIComponent/validateProperties()
            at mx.managers::LayoutManager/validateProperties()
            at mx.managers::LayoutManager/doPhasedInstantiation()
            at mx.managers::LayoutManager/doPhasedInstantiationCallback()
Any kind of help is appreciated.
Hani,
___________________________________________________________________________________________________________
Screenshots:
1- Warnings:
2- Error:
Here is the code I used:
<?xml version="1.0" encoding="utf-8"?>
<s:Application xmlns:fx="http://ns.adobe.com/mxml/2009"
                     xmlns:s="library://ns.adobe.com/flex/spark"
                     xmlns:mx="library://ns.adobe.com/flex/mx"
                     xmlns="http://ns.adobe.com/air/application/4.6"
                     xmlns:esri="http://www.esri.com/2008/ags">
      <s:layout>
            <s:VerticalLayout gap="10"
                                      horizontalAlign="center"
                                      paddingBottom="20"
                                      paddingLeft="25"
                                      paddingRight="25"
                                      paddingTop="20"/>
      </s:layout>
      <fx:Script>
            <![CDATA[
                  import com.esri.ags.FeatureSet;
                  import mx.controls.Alert;
                  import mx.rpc.AsyncResponder;
                  private function doQuery():void
                        queryTask.execute(query, new AsyncResponder(onResult, onFault));
                        function onResult(featureSet:FeatureSet, token:Object = null😞void
                              // No code needed in this simple sample, since the
                              // graphics layer is bound to the query result using
                              // graphicProvider="{queryTask.executeLastResult.features}"
                        function onFault(info:Object, token:Object = null😞void
                              Alert.show(info.toString(), "Query Problem");
      </fx:Script>
      <fx:Declarations>
            <!-- Layer with US States -->
            <esri:QueryTask id="queryTask"
                                    showBusyCursor="true"
                                    url="http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer/5"
                                    useAMF="false"/>
            <esri:Query id="query"
                              outSpatialReference="{myMap.spatialReference}"
                              returnGeometry="true"
                              text="{qText.text}">
                  <esri:outFields>
                        <fx:String>MED_AGE</fx:String>
                        <fx:String>POP2007</fx:String>
                  </esri:outFields>
            </esri:Query>
      </fx:Declarations>
      <s:Panel height="60"
                   backgroundColor="0xB2BFC6"
                   title="Query a layer (search for a state)">
            <s:layout>
                  <s:HorizontalLayout/>
            </s:layout>
            <s:TextInput id="qText"
                               width="100%"
                               enter="doQuery()"
                               text="California"/>
            <s:Button click="doQuery()" label="Do Query"/>
      </s:Panel>
      <esri:Map id="myMap">
            <esri:extent>
                  <esri:Extent xmin="-14298000" ymin="2748000" xmax="-6815000" ymax="7117000">
                        <esri:SpatialReference wkid="102100"/>
                  </esri:Extent>
            </esri:extent>
            <esri:ArcGISTiledMapServiceLayer
                  url="http://server.arcgisonline.com/ArcGIS/rest/services/World_Physical_Map/MapServer"/>
      </esri:Map>
</s:Application>
HaniDraidi
Dear Bjorn,
Thank you very much for the attention and the links, they seem to be very helpful to me as a beginner.
Thank you again!
