token based security and 10.1 printing gp service
14092
25
09-21-2012 07:13 AM
Drew
Has anyone successfully produced a print when using a secured service?
I am getting the following error..
Error executing tool.: Layer "ArcGISDynamicMapServiceLayer405": Unable to connect to map server at    [...Web map URL with token written here......] Failed to execute (ExportWebMap). Failed to execute (Export Web Map)
Is there something I need to configure?
Drew
DrewDowling
AM
savaadaisu
Thanks for you input. I eventually went with using a proxy page instead of using a token directly and this solved my problems. Hope this helps others.
MiriEshel
Hi Drew,
What do you mean by : "using a proxy page instead of using a token directly "?
I use a proxy too in order to avoid typing the user & password but I cannot  print any map with secured layers.
Have you succeeded?
Miri
DrewDowling
Hi Drew,
Have you succeeded?
Miri
I set up a proxy page using the esri proxy page code sample found on github. I then added both the print service and the secured map service to my flex app making sure to point the .Proxy property of each service to the proxy page I had just set up. This enabled me to remove the .Token property from the map service. When I did this the print task worked.
FYI more info on the bug here
XiaowenHuang
I have the exact same issue with print task in javascript API. Could you let me know how do you setup proxy for print service? Thanks!
DrewDowling
Here is the esri source code
Esri/resource-proxy · GitHub
download your preferred language and then install as a web app on oyur web server.
Next play around with the proxy.config settings until they are right for your environment. e.g.
<ProxyConfig allowedReferers="*"
             mustMatch="false">
    <serverUrls>
        <!--<serverUrl url="http://services.arcgisonline.com"
                   matchAll="true"/>-->
      <serverUrl url="http://MyWebServer:6080/arcgis/rest/services"
        username="MyID"
        password="MyPass"
        rateLimit="600"
        rateLimitPeriod="60"
        matchAll="true">
      </serverUrl>
    </serverUrls>
</ProxyConfig>
You might need to/probably should lock down what is available through the proxy. There are instructions on how to do this in the readme.txt
LanceGosby
The bug that Drew mentioned applies to me. We are on 10.1. Here is what I've got and how I got around it.
I have a map service and a custom print service within a secured folder. I am able to print the map if I print the entire dynamic map service. I can even set the visibleLayers property to hide some layers. As soon as I try to print an individual feature layer from this map, it doesn't work. I have tried the exact same thing on an unsecured map service and it works as expected.
I wanted to print an individual feature layer so I could set the selectionObjectIds property in my webmap JSON to highlight a particular feature. As a work around, I added a graphics layer to the webmap JSON. I grabbed the selected feature's geometry and used that to define the graphics layer.
We can't upgrade beyond 10.1 just yet. Hopefully this helps someone.
