thematic
1058
04-12-2013 08:06 AM
lifeEsri
I want to create a thematic map but i'm using ArcGis server 10 not 10.1
there is ia way to do that,thank's
BjornSvensson
Esri Alum
ArcGIS 10.1 can create dynamicly rendered maps on the server.
http://resources.arcgis.com/en/help/flex-api/concepts/index.html#/Dynamic_Rendering/017p0000002q0000...
Before 10.1 you had two main options:
1) Pre-create the thematic maps ... with the limitation that you couldn't change the rendering.
Examples: http://services.arcgisonline.com/ArcGIS/rest/services/Demographics
2) Do the rendering on the client.  Using feature layer (not feature service).
Examples:
http://resources.arcgis.com/en/help/flex-api/samples/index.html#/Based_on_MapServer_layer/01nq000000...
http://resources.arcgis.com/en/help/flex-api/samples/index.html#/Using_Renderers/01nq00000052000000/
BjornSvensson
Esri Alum
Examples:
lifeEsri
Examples:
thank you very mutch 🙂
