storing geometry in array
963
01-13-2012 10:05 AM
DebbieAlger
I want to store geometries in an array but am getting errors retrieving the data. I have done a test on length and it contains objects.
private var geometryArray:Array;
geometryArray = new Array();
for each(var graphic:Graphic in fs.features)
               geometryArray.push([graphic.geometry]);
later .....   map.extent = geometryArray.extent.expand(3);   ===> ERROR  HERE
Error #1034: Type Coercion failed: cannot convert []@19e9c971 to com.esri.ags.geometry.Geometry.
I have tested with just one instance and it works fine, such as this..
var geom:geometry;
geom =  graphic.geometry;
..... map.extent = geom.extent.expand(3);
______________________________________
so I know the geometry is fine...
any ideas on the array issue??
thanks
RobertScheitlin__GISP
Debbie,
   So why are you store the geometry in an array and then adding it to an array?
Try:
geometryArray.push(graphic.geometry);
Debbie,
Try:
DebbieAlger
Well color me silly, that was it.
THanks so much!
