Start flex map to zoom to an ID in the URL
2784
09-29-2014 09:05 AM
LesHampton
I need to pass a parcel number to a Flex application and have the application zoom to the parcel specified in the URL
RobertScheitlin__GISP
Les,
   If you are talking about a Flex Viewer application than you can use the eSearch Widget for this:
http://www.arcgis.com/home/item.html?id=5d4995ccdb99429185dfd8d8fb2a513e
If you talking about a custom Flex API application then you will have to develop your own capability to do this using a QueryTask.
ReneRubalcava
Esri Frequent Contributor
A good DIY solution is using the IBrowserManager interface.
Adobe Flex 4.6 * Using the BrowserManager
You may need to use setTimeout to wait for the map to load and all your layers. Something like this.
map.addEventListener(MapEvent.LOAD, function():void {
  setTimeout(function():void {
    bm = BrowserManager.getInstance();
    bm.init();
    var o:Object = URLUtil.stringToObject(bm.fragment);
    var type:String = String(o.view);
    if (type != "") {
      switchMap(views[type]); // I use it for custom views
  }, 500)
LesHampton
Thank You, I will give the Suggestions a try
