Splash Widget
3170
09-27-2010 10:57 AM
CarlAlexander
When I use the splash widget an icon still shows up in the widget container for the splash widget on the map.  Is there a way to not have an icon appear?
<widget preload="open"
                config="widgets/Splash/SplashWidget.xml"
                url="widgets/Splash/SplashWidget.swf"/>
RobertScheitlin__GISP
Carl,
   Sure just remove these lines of the SplashWidget.xml
<p align='center'>
            <img src='assets/images/globe.png' width='140' height='140' />
        </p>
DasaPaddock
See config-all.xml for example usage of the Splash widget. It has it's own place in the config like this:
<splashpage label="ArcGIS Viewer for Flex" config="widgets/Splash/SplashWidget.xml" url="widgets/Splash/SplashWidget.swf"/>
JohnCartwright1
What about the size of the splash container? I have attempted to use the splash widget and even if I manually resize it by setting heights to something like 500 x 400 pixels it still displays as a very small container with scroll arrows. Any suggestions? I am sure this is quite simple and just something I am overlooking.
DasaPaddock
Did you try to change the width and height in SplashWidget.xml?
The default is:
    <width>375</width>
    <height>375</height>
All,
   Here is a enhanced version of the splash widget that you may be interested in:
http://www.arcgis.com/home/item.html?id=8492794bf5bf4358bca6cce29db31b14
