Spatial Filter Problem in QueryBuilder Widget
904
08-24-2010 05:09 AM
MattO_Connell
Hello,
I am trying to customize the sample flex viewer version 1.3 and I am having an issue with the QueryBuilder Widget. The attribute filter is working just fine with my map services but when I apply a spatial filter the widget does not move out of the "Buffering Geometry" phase. After I click the map to set a point, polygon, or line, it just says "Buffering Geometry" forever. Thanks in advance for any advice.
Matt
ErwanCaradec
i had the same problem before to correctly set the url of the rest geometry service in the widget configuration file : QueryBuilderWidget.xml.
http://yourArcGisserver/ArcGIS/rest/services/yourGeometryService...
hope that help.
Regards
Erwan Caradec
ErwanCaradec
Hi matt,
i had some other problems with null values on entity attributes so i change the line n°264 in QueryBuilderWidget.mxml
old line >
value = obj[fld].toString();
line changed >
if (obj[fld] != null) {value = obj[fld].toString();}
regards
Erwan
