Single line address field usage in flex
1905
01-11-2011 11:35 AM
JacksonTrappett
Hi, I'm trying to write some code to use an address locator and I want to use the single line address field.  I have set up my address object with just the single line:
var myAddress:Object =
  SingleLineInput: searchBox.text
However I can not give the address field the correct name.  According to my locator the field should be called:
"Single Line Input"
as seen in this JSON code in the locator's rest endpoint:
"singleLineAddressField" : {
    "name" : "Single Line Input",
    "type" : "esriFieldTypeString",
    "alias" : "Full Address",
    "required" : false}
The problem is that Flex will not allow me to pass a field name of "Single Line Input" because it has spaces in it.  All of the other field names work fine since they have no spaces.  How can I use this field name in my flex code?
Thanks to anyone who can help,
Jackson
RobertScheitlin__GISP
Jackson,
   Normally the actual input name will not contain spaces so I would check your REST Service directory and look for address fields like I show in the attached image.
JacksonTrappett
That's where I got my field name, here's a screen-shot of that area in my service.
Jackson,
   try:
var myAddress:Object = new Object();
    myAddress["Single Line Input"] = searchBox.text;
JacksonTrappett
That worked, thanks!
I just spent about 45 minutes searching for that syntax before finally posting!
