Simple Legend Problem
3468
7
06-14-2011 12:11 PM
TomJansen
I'm trying to create a simple legend that shows the layers and symbology from a Dynamic Map Service.  When I use code from the ESRI legend component sample the legend appears as an icon with a red circle crossed out.  Attached is the icon, below is my code. Any ideas why this is happening?  Thanks.
<?xml version="1.0" encoding="utf-8"?>
<s:Application xmlns:fx="http://ns.adobe.com/mxml/2009"
      xmlns:s="library://ns.adobe.com/flex/spark"
      xmlns:esri="http://www.esri.com/2008/ags"
      pageTitle="Legend Component">
 <esri:Map id="myMap">
  <esri:extent>
   <esri:Extent xmin="-10753431" ymin="4624151" xmax="-10737799" ymax="4635884">
    <esri:SpatialReference wkid="102100"/>
   </esri:Extent>
  </esri:extent>
  <esri:ArcGISDynamicMapServiceLayer id="baseLayers"
   url="http://arc-srv-02/ArcGIS/rest/services/Flex_Services/Scott_Base_Layer_Flex/MapServer/">
  </esri:ArcGISDynamicMapServiceLayer>
 </esri:Map>
 <esri:Legend id="myLegend"
     width="250" height="100%"
     layers="{[ baseLayers ]}"
     map="{myMap}"
     respectCurrentMapScale="true"/>
</s:Application>
KomanDiabate
I believe you need server 10 to have the legend working properly or you will get the cross over layer symbol..
TomJansen
Thanks for the response...though I am using server 10.
R__CraigHolmes
double check your spatial reference
ZahidChaudhry
Check from the service directory
and you should be able to see your legend. If you can see it there, you can generate it in your app..
KenBuja
MVP Esteemed Contributor
Have you set the visible layers for the service?
MatthewZetterholm
Just wondering if you ever resolved this issue?  I am having the same problem.
KomanDiabate
Make sure you are running server 10 and you can see Legend info in your map rest service. The legend is being drawn from the rest services
