Show InfoWindow on a Polyline
2984
10-05-2011 12:15 PM
TylerWaring
Greetings Everyone,
            I would like to show an InfoWindow on a polyline. What is the best way to affix the InfoWindow to a line?
Thanks, Tyler Waring
KenBuja
The Identify Features sample has the code if you click on the map.
In one of my applications, I have a datagrid containing polylines of ROV transects. When you click on one of the items in the datagrid, an InfoWindow is placed at the midpoint of the transect. This function (the click event on the datagrid rovGrid) is how I did it.
private function rovGrid_Click():void
    var obj:Object = rovGrid.selectedItem;
    if (obj != null)
        MainMap.infoWindow.hide();
        var graphic:Graphic = findGraphicByAttribute(obj, layerROVGraphics);
        var path:Polyline = graphic.geometry as Polyline;
        var halfway:int = path.paths[0].length/2;
        var mapPoint:MapPoint = path.getPoint(0,halfway);
        if (graphic == null)
            Alert.show ("This transect cannot be found");
            return;
        if (chkROVZoom.selected)
            MainMap.extent = graphic.geometry.extent;
            if (!MainMap.extent.containsExtent(graphic.geometry.extent)) {MainMap.level--;}
        //I didn't include the function to fill the content of the infoWindow
        MainMap.infoWindow.content = Functions.createVideoWindow(graphic);
        MainMap.infoWindow.label = "Transect: " + graphic.attributes.Name;
        MainMap.infoWindow.show(mapPoint);
private function findGraphicByAttribute(attributes:Object, graphicLayer:GraphicsLayer):Graphic
    for each (var graphic:Graphic in graphicLayer.graphicProvider)
        if (graphic.attributes["OBJECTID"] == attributes["OBJECTID"])
            return graphic;
    return null;
