SFV : Zoom To Searched Record - Basemaps disappears
1149
04-14-2010 10:06 AM
NitinBele
Hello,
When searched record is clicked for zooming in , the basemap (ESRI_StreetMap_World_2D) disappears .
But show up again when zoom Out.
However,at that extent ESRI_Imagery_World_2D is visible.
Have tried to provide some hard code values in clickRecord function in SearchWidget.mxml ,but no change.
I am using spatial reference value -2229  in SearchWidget.xml.
Please suggest.
regards,
Nitin Bele
RobertScheitlin__GISP
Nitin,
   Just change your zoomscale in the SearchWidget.xml to a higher value. It is 2000 by default, make it 5000.
NitinBele
Thanks Robert,
But it still acts in the same way.
Attchaching my xml herein. could you pls. take a look ?
<?xml version="1.0" ?>
<configuration>
<layers>
  <layer>
   <name>Structure Existing</name>
   <url>http://g2vlgiw02/ArcGIS/rest/services/IT-GIS/TWG_Main/MapServer/21</url>
   <expression>STR_NAME LIKE '[value]%'</expression>
   <textsearchlabel>Search by Structure Name [Example: M107-T1]</textsearchlabel>
   <graphicalsearchlabel>Use one of the graphical search tools to select incidents</graphicalsearchlabel>
   <fields>STR_NAME</fields>
   <titlefield>STR_NAME</titlefield>
   //<linkfield></linkfield>
   <gridfields>STR_NAME,LINE_NAME,UPD_DATE,LAT,LON</gridfields>
   <gridhyperfields showalias="false"/>
   <zoomscale>5000</zoomscale>
  </layer>
  <layer>
   <name>Structure New</name>
   <url>http://g2vlgiw02/ArcGIS/rest/services/IT-GIS/TWG_Main/MapServer/22</url>
   <expression>NAME LIKE '[value]%'</expression>
   <textsearchlabel>Search by Structure Name [Example: M22-T5]</textsearchlabel>
   <fields>NAME</fields>
   <titlefield>NAME</titlefield>
   <gridfields>NAME,STATUS,LINE_NAME,KV,STATION</gridfields>
  </layer>
</layers>
<spatialReference>2229</spatialReference>
<geometryservice></geometryservice>
<!--Default .csv file name-->
<csvdefaultname>Selected Records</csvdefaultname>
</configuration>
regards,
Nitin Bele
Nitin,
   Is the icon for the returned search result in the correct location on the map?
NitinBele
Yes Robert,
It is in the exact location of the searched feature.
