SFV 1.3 Pass URL to Search parcels
5017
18
05-06-2010 07:59 AM
LeeAllen
I would like to pass a URL string from our property search page like http://...PRCL_ID=1420303004021000 to the flex app search so that when users click on a link on the property search page, this ID is sent to the app and zooms to the parcel automatically. Is this possible?
I have the search widget setup to search ID's when typed in.
http://gis.snco.us/gisviewer
Lee
RobertScheitlin__GISP
Lee,
    It is not simple as pie but here is the link to accomplish just that.
http://forums.esri.com/thread.asp?c=158&f=2421&t=266031&mc=47
CoryHines
Hi Lee,
Take a look at this forum as well.  If I'm understanding what you're looking for correctly we have this working on our site.  The forum is quite long, but sprinkled throughout it are all the steps you'll need.
http://forums.esri.com/Thread.asp?c=158&f=2421&t=294907&mc=104
http://gis.linncounty.org/maps/index.html?parcelnum=133647600700000
Cory
LeeAllen
I have followed all of the steps in forum, I think I'm close.  After compiling, I get an error in my SiteContainer.mxml (Description Resource Path Location Type
1021: Duplicate function definition. SiteContainer.mxml /Flexviewer1.3/src/com/esri/solutions/flexviewer line 176 Flex Problem)
here is the code in the .mxml file:
public function init():void
    _container = this;
    _lock = true; //make sure only one container is created.
    initLogging();
    //make sure the event bus is ready.
    _containerEventDispatcher = EventBus.getInstance();
    //prepare to show error message
    SiteContainer.addEventListener(AppEvent.APP_ERROR, showError);
    //listen for the config data to be loaded
    SiteContainer.addEventListener(AppEvent.CONFIG_LOADED, config);
    //tell the modules it's on business.
    SiteContainer.dispatch(SiteContainer.CONTAINER_INITIALIZED);
I can post all of .mxml files if necessary.
Thanks for any help!
Lee
CoryHines
Hi Lee,
I don't know if this matter or not, but there are a couple of spaces in the code that may have just been how they were copied into the forums.
SiteContainer.addEventListener(AppEvent.CONFIG_[LOA DED, config);
SiteContainer.dispatch(SiteContainer.CONTAINER_INI TIALIZED);
If that's not in your actual code could you post your entire SiteContainer and I'll take a look at it.
Cory
LeeAllen
Here is the site container and the mapmanager(just in case you need to take a peek at it) mxml files.  Thanks for taking a look.  Lee
CoryHines
Hi Lee,
See if this SiteContainer works.  I noticed a couple of lines of code that were missing.  Hopefully this is all that's missing.
I didn't check the MapManager, but if this doesn't work I'll take a look at that too.
Cory
LeeAllen
Cory,
I can't get the code to come through with that file (saved and renamed without .zip), could you try again or put code in reply for me to copy?
Thanks!
CoryHines
Hope this helps.
<?xml version="1.0" encoding="utf-8"?>
// Copyright © 2008 - 2009 ESRI
// All rights reserved under the copyright laws of the United States.
// You may freely redistribute and use this software, with or
// without modification, provided you include the original copyright
// and use restrictions.  See use restrictions in the file:
// <install location>/FlexViewer/License.txt
<mx:Canvas xmlns:mx    ="http://www.adobe.com/2006/mxml"
   xmlns:comp    ="components.*"
   width     ="100%"
   height     ="100%"
   horizontalScrollPolicy ="off"
   verticalScrollPolicy ="off"
   creationComplete  ="init()" >
    <mx:Script>
  <![CDATA[
   import com.esri.solutions.flexviewer.AppEvent;
   import com.esri.solutions.flexviewer.components.ErrorWindow;
   import mx.containers.TitleWindow;
   import mx.logging.Log;
      import mx.logging.LogEventLevel;
      import mx.logging.targets.TraceTarget;
   import mx.managers.PopUpManager;
      public static const NAVIGATION_ZOOM_FULL:String   = "zoomfull";
      public static const NAVIGATION_ZOOM_PREVIOUS:String  = "zoomprevious";
      public static const NAVIGATION_ZOOM_NEXT:String      = "zoomnext";
   public var configManager:ConfigManager;
   public var uiManager:UIManager;
   public var controller:Controller;
   public var mapManager:MapManagercopy;
   public var widgetManager:WidgetManagerDocked;
   public var dataManager:DataManager;
   private static var _container:SiteContainer;
   private static var _lock:Boolean = false;
   private var _containerEventDispatcher:EventBus;
   public static var CONTAINER_INITIALIZED:String = "containerInitilized";
   private var configData:ConfigData;
    _container = this;
    initLogging();
   private function config(event:AppEvent):void
       configData = event.data as ConfigData;
   public function getWidgetId(widgetLabel:String):Number
    var id:Number;
    for (var i:Number = 0; i < configData.configWidgets.length; i++)
           if (configData.configWidgets.label == widgetLabel)
            id = configData.configWidgets.id;
          return id;
             * Initialize the logging. As an example, the logging is setup to only
             * log the fatal event during the RPC related network communication,
             * such as HTTP call to obtain configuration file.
            private function initLogging():void {
                // Create a target.
                var logTarget:TraceTarget = new TraceTarget();
                // Log only messages for the classes in the mx.rpc.* and
                // mx.messaging packages.
                logTarget.filters=["mx.rpc.*","mx.messaging.*"];
                // Log on fatal levels.
                logTarget.level = LogEventLevel.FATAL;
                // Add date, time, category, and log level to the output.
                logTarget.includeDate       = true;
                logTarget.includeTime       = true;
                logTarget.includeCategory   = true;
                logTarget.includeLevel      = true;
                // Begin logging.
                Log.addTarget(logTarget);
      //to make sure the the children are visible.
      private var isAddChild:Boolean = true;
      protected override function commitProperties():void
          super.commitProperties();
          if (isAddChild)
           addChild(mapManager);
           addChild(controller);
           addChild(widgetManager);
           isAddChild = false;
      private function showError(event:AppEvent):void
             var errorWindow:ErrorWindow = ErrorWindow(PopUpManager.createPopUp(this, ErrorWindow, true));
             // Add title to the title bar.
             errorWindow.errorMessage = event.data as String;
             // Add a close button.
             // To close the container, your must also handle the close event.
             errorWindow.showCloseButton=true;
        static functions as proxy of Event Bus
   public static function getInstance():SiteContainer
    if (!_lock){
     _container = new SiteContainer();
     _lock = true;
    return _container;
      //the following are the methods to allow modules access event bus via the contains.
   public static function addEventListener(type:String, listener:Function, useCapture:Boolean=false, priority:int=0, useWeakReference:Boolean=false):void
       EventBus.getInstance().addEventListener(type, listener, useCapture, priority, useWeakReference);
      public static function removeEventListener(type:String, listener:Function, useCapture:Boolean=false):void
       EventBus.getInstance().removeEventListener(type, listener, useCapture);
      //this is the simplest way of communicate. Just use a string.
      public static function dispatch(type:String):Boolean
       return EventBus.getInstance().dispatch(type);
      public static function dispatchEvent(event:Event):Boolean
       var eventBase:EventBus = EventBus.getInstance();
          return eventBase.dispatchEvent(event);
      public static function setStatus(status:String):void
       dispatchEvent(new  AppEvent(AppEvent.SET_STATUS, false, false, status));
    _container = this;
    initLogging();
    var id:Number;
    return id;
   //Add this to the sitecontainer
    </mx:Script>
    <mx:Metadata>
     [DefaultProperty("childen")]
    </mx:Metadata>
</mx:Canvas>
LeeAllen
Cory, thanks.  I got everything to compile with no errors, but like many before me, nothing happens when the site runs.  I looked at it in firebug, and it is not getting the GET query.  The site is http://gis.snco.us/gisviewer.  The test URL would be http://gis.snco.us/gisviewer/index.html?PRCL_ID=133647600700000. I have attached the SiteContainer.mxml, MapManager, and Search.mxml.
Thanks for any help!!!
Cheers and happy holidays, I''m out for the weekend.
