Setup Amethyst plug-in for VS2008
1329
05-16-2011 05:42 AM
AlexanderAnkrah
Hi Flex folks,
Wondering if any one could give me pointers on how to set up and run the Amethyst plug in for Visual Studio 2008.
I think I've done all there is to do, got the intellisense and all and all coming through OK but can't seem to get the map to display, I'm getting 2 types of errors
1. saying the project is out of date
2. the errors below...
User exception thrown (VerifyError: Error #1014: Class mx.controls.sliderClasses::Slider could not be found.
at com.esri.ags::Map()
at FlexApplicationThree/_FlexApplicationThree_Map1_i()
at FlexApplicationThree/_FlexApplicationThree_Array1_c()
....and more
Any help given would be very much appreciated.
dON
AlexanderAnkrah
UPDATE:
Aside Amethyst, are there any other plugin for VS 2008 that one can use in conjunction with ESRI Flex API?
Thanks
AlexanderAnkrah
Not quite Amethyst but it works for me...
if you still an IDE either than Flex Builder check out this post
http://forums.arcgis.com/threads/24861-integrating-.net-application-with-Flex-API?p=102346#post10234...
Thanks to our Aussie brothers and sisters for the step by step guide
Good Luck
