Set Default Date in Edit Widget??
3403
09-13-2010 12:43 PM
JordanHoaglund1
I hope this is an easy question...but how would I go about setting the default date for a date field in the edit widget???  It is currently set (out of the box) as 12/29/1899...
Thank you so much.
-Jordan
SimonMorgan
Thank you so much.
-Jordan
You set this in the MXD by setting a default value for the date field in the editing template.
JordanHoaglund1
Thanks Simon!
YeongLin
Is it possible to set date field Default to current date, .e.g., Date() ?
