Send PDF generated from map as an email
739
10-27-2010 01:04 AM
shafitrumboo
I have to implement  user should be able to  email the current map view as PDF.
I'm able to generate PDF using ALIVEPDF and I'm sure I can implement it using serverside code in asp.net. Can I do same in flash without opening new window.
JustinGreco
You can't send emails directly from Flex, you need to write a script on the backend.  I'm sure you can find some samples online.  I use a PHP script to send emails.
