security
2069
9
07-24-2012 04:02 AM
anjelinaponker
Hi
How can I add a security for my widgets? for example I want some users can see my edit widget some users no. What should I do?
Regards
A.ponker
RobertScheitlin__GISP
Anjelina,
   Remember that this is the Flex API forum and not the Flex Viewer forum:
http://forums.arcgis.com/forums/111-ArcGIS-Viewer-for-Flex
where this question belongs.
You can control what widgets are available to users based on different config.xml files that have the edit widget removed. Many people have a custom ASP.net front end to their viewer that handles login and then based on login they are directed to the appropriate config.xml when the viewer is launched. As far as something out of the box "widget security" there is NONE.
AnthonyGiles
Honored Contributor
Anjelina,
Below is a link to to an esri video from the developer summit in March where a User presented on this subject:
http://video.esri.com/iframe/1277/000000/width/960/0/00:00:00
You may this helpful
Regards
Anthony
anjelinaponker
Hi
I,m using Visual studio and SQL Server for adding authentication page. I dont know how can I add multiple config.xml ? And where shoul I setting security for these config.xml files?
AnthonyGiles
Honored Contributor
Anjelina,
You can just copy the config.xml that you have and rename it. When you open your application at the end of the URL add ?config=newconfigfile.xml
See:
http://help.arcgis.com/en/webapps/flexviewer/help/index.html#/Viewer_URL_parameters/01m3000000290000...
Regards
Anthony
parvazparvaz
Hi
I added new config, But how can I make relationship for this new config and a user or a rule in visual studio?
anjelinaponker
Hi
anjelinaponker
Anjelina,
Hi
Ho can I make relationship for this new config and a user or a rule in visual studio? Because each user group should access to a config. please help me
Regards
A.ponker
Anjelina,
   Sorry I do not help with Visual Studio or .Net questions, which is what the answer to your question would involve.
parvazparvaz
Anjelina,
Hi
Is there any solution in Flex application?
