Secured Service with Windows Auth
971
06-15-2010 01:35 PM
JoshuaKeller
I'm using the sample viewer 1.3 and am trying to get it to work with services published on a secondary server that has security enabled and is using windows authentication. Prior to enabling security on a clean AGS install I published the two services, added them to my flex config.xml and everything works fine. They show up in the TOC, can be enabled, etc.
I then added a windows group to the service permissions, one service I belonged to the group one service I did not. When viewing the REST URL in IE I am able to see only the service that for the group like I belonged to, as expected. I tried switching permissions around and everything when looking at the REST URL shows up as expected, giving me access to view the correct services, and the ability to view them using the javascript link as I would expect.
I made no changes to my flex config.xml and I am no longer able to see either service...the service label is listed in the TOC but I am unable to expand it, view it, etc. Is there something I'm missing here? I've searched the forum and not been able to find this same situation. I added  <allow-http-request-headers-from domain="*" headers="*"/> to my crossdomain.xml file but that did not help.
Any help would be appreciated,
JoshuaKeller
I figured out the problem, I had missed disabling anonymous access on the REST folder when I did it to the services folder. Seems odd that it performed as expected when viewing it from the browser directly, but after making that change everything works fine.
