Search Widget FlexViewer 2.0
1042
08-02-2010 07:43 AM
JoshuaKalov
I have configured the xml file for the Search Widget with the FlexViewer 2.0.  I am asking it to return 4 fields, 1 being a "titlefield" and 1 being a "linkfield."
When I use the application and do a search, "SHAPE_Length" and "SHAPE_Area" fields display even though I don't have them listed in the "fields" section of the xml file.  How do I get them to not display?  Is this a bug?
Another issue I am having is that the link is only showing in the info pop-up.  It odes not show in the "Results" section of the Search widget box.
Anyone know why this wouldn't be working right?
Thanks
RobertScheitlin__GISP
Joshua,
   The link in the search results for Flexviewer 2.0 does not exist anymore (don't raelly know why they omitted it). And the shape_area and shape_Length has been a bug/feature since SFV 1.0. In the SearchWidget.mxml line 415 replace the existing line with this to fix it.
if (fld.toUpperCase() != queryTitleField.toUpperCase() &&(fld.toUpperCase() != "SHAPE_LENGTH") && (fld.toUpperCase() != "SHAPE_AREA"))
JoshuaKalov
Joshua,
Thanks Robert.  You are always great about responding with solutions.
To any ESRI folks that saw my other post about documentation, this is exactly the kind of thing I am talking about.  Is this a bug I should report?  Was this intentionally left out?
I guess that goes for the SHAPE_LENGTH/SHAPE_AREA bug too.  If that has been around since 1.0, has it just not been reported?  Is there a reason it has never been fixed?
If ESRI utilized bug tracking/reporting systems like most web software dev. uses, it would be easier to know the answers to these things without having to guess.
ashwiniwakchaure
I modified searchwidget_louisville.xml in the sample flex viewer 2.0, and put a layer from out service instead of Louisville layers, however the widget still shows the combobox and Louisville layers.. I don't know why? can you help please?
Thanks.
