Search widget error
1108
05-14-2010 02:51 AM
BobbyOliver
I am getting 2 different error with search widget.  Every layer but 1 gives me this Error #1009: Cannot access a property or method of a null object reference.
I have one layer that returns this error [RPC Fault faultString="" faultCode="400" faultDetail="Unable to perform query. Please check your parameters."]
This is happening in both application I am running.  They both use the same services.
Thanks for any help.
Bobby
SusanMordy1
For # 1 error, see: http://forums.arcgis.com/threads/2748-SFV-1.3-Search-Widget-returning-errors?highlight=search
For error #2, there may be a problem with your expression query statement.
<expression></expression>
BobbyOliver
I have tried clearing the REST cache and this did not solve the problem.  This tool worked a couple of weeks ago and now it doesn't.  I am not sure what has changed.  I have removed a few layers from the dynamic services, but that is the only change I have made.  I have not changed the code from when it worked to the point where I started getting the error.
It almost seems as though the search tool can longer connect to the services.
BobbyOliver
I have resolved this problem . Thanks.
SeanSweeney
Can you post your resolution?  We are having the same issue and I'm looking for ideas.
