Search element and flash it, but different elements flash on the same point
743
05-22-2012 07:49 PM
guojing
ArcGiS engine 10
IDE??VS2010 C++
I search element(Geometry type is point), and want to flash it use FlashShape method. But i search different elements, the FlashShape always flash on the same point, why? I get point (X, Y) through point->get_X(&X) and point->get_Y(&Y), and compare it with mapX, mapY where i through mouse click event, they are different. The following is code snippet??
    CSearchDlg dlg;
    if (dlg.DoModal() == IDOK)
        const CString layerName = dlg.m_layerName;
        const CString featureName = dlg.m_featureName;
        CString whereClause;
        whereClause.Format(_T("name = '%s'"), featureName);
        HRESULT hr;
        IQueryFilterPtr pQueryFilter(CLSID_QueryFilter);
        pQueryFilter->put_WhereClause(CComBSTR(whereClause));
        IMapPtr pMap;
        m_mapCtrl->get_Map(&pMap);
        long layerCount = 0;
        pMap->get_LayerCount(&layerCount);
        BSTR bsCurLayerName = NULL;
        BSTR bsLayerName = CComBSTR(layerName);
        int i;
        ILayerPtr pLayer = NULL;
        for (i = 0; i < layerCount; i++)
            pMap->get_Layer(i, &pLayer);
            pLayer->get_Name(&bsCurLayerName);
            if (_tcsicmp(bsCurLayerName, bsLayerName) == 0)
                break;
        if (layerCount == i)
            CString msg;
            msg.Format(_T("Can not find layer %s"), layerName);
            AfxMessageBox(msg);
            return;
        IFeatureLayerPtr pFeatureLayer(pLayer);
        if (pFeatureLayer == 0)
            TRACE(_T("Not found\n"));
            return;
        IFeatureSelectionPtr pFeatureSel(pFeatureLayer);
        hr = pFeatureSel->SelectFeatures(pQueryFilter, esriSelectionResultNew, VARIANT_FALSE);
        if (FAILED(hr))
            TRACE(_T("hr %08X\n"), hr);
            return;
        ISelectionSetPtr pSelectionSet;
        hr = pFeatureSel->get_SelectionSet(&pSelectionSet);
        if (FAILED(hr))
            return;
        esriICursorPtr pCursor;
        hr = pSelectionSet->Search(NULL, VARIANT_TRUE, &pCursor);
        if (FAILED(hr))
            return;
        IFeatureCursorPtr pFeatureCur = pCursor;
        IFeaturePtr pFeature;
        pFeatureCur->NextFeature(&pFeature);
        IActiveViewPtr pActiveView;
        m_mapCtrl->get_ActiveView(&pActiveView);
        IScreenDisplayPtr pScreenDisplay;
        pActiveView->get_ScreenDisplay(&pScreenDisplay);
        while (pFeature != NULL)
            IGeometryPtr pGeometry;
            pFeature->get_Shape(&pGeometry);
            esriGeometryType ShapeType;
            pGeometry->get_GeometryType(&ShapeType);
            if (esriGeometryPoint == ShapeType)
                ISimpleFillSymbolPtr pFillSymbol(CLSID_SimpleFillSymbol);
                IMarkerSymbolPtr pMarkSymbol(CLSID_SimpleMarkerSymbol);
                ISymbolPtr pSymbol;
                IRgbColorPtr pColor(CLSID_RgbColor);
                pColor->put_RGB(RGB(255, 0, 0));
                pMarkSymbol->put_Size(20);
                pMarkSymbol->put_Color(pColor);
                pSymbol = (ISymbolPtr) pMarkSymbol;
                pSymbol->put_ROP2(esriROPNotXOrPen);
                pScreenDisplay->UpdateWindow();
                m_mapCtrl->FlashShape(pGeometry, 10, 400,  _variant_t((IUnknown* )pSymbol));
RobertScheitlin__GISP
You are posting to the the Flex API form... You need to be posting this to the dot NET forum instead.
http://forums.arcgis.com/forums/9-ArcGIS-Server-.NET
