Screen Resolution
6938
16
06-09-2011 02:21 AM
MohammedIsmail
Hi
i want my application to run on any resolution weather it is 600/800/1024
like it should get displayed full when i open it without any off screen business
how can i do that
Thanks
Ismail
Drew
Set the width and height of the application to 100%.
NasifAlshaier
Hi Andrew.
I have the width and the height of the application set to 100% and it still not working... any other idea?
thank you
Nasif
Drew
Hi Andrew.
thank you
Nasif
make sure your Map and its outer containers (i.e: BorderContainer, HGroup, VGroup) are also set to 100% width and height
NasifAlshaier
Hi ANdrew...
thank you for the quick response..
which file these (BorderContainer, HGroup, VGroup) will be under?
Thanks
Drew
Hi ANdrew...
Thanks
Can you post your MXML file so I can see how your application is configured.
NasifAlshaier
Hi Andrew..
Iattached the mapmanger file..
Thanks
Drew
Sorry, the word document is unreadable.
Basically you have to make sure every parent container the map is in has a width and height of 100%
So.. If the map is contained in border containers, HGroups, VGroups etc.. make sure they ALL have a width and height of 100%
NasifAlshaier
Hi Andrew..
I zip the files..
Thanks
RobertScheitlin__GISP
Nasif,
   Because you are posting to the Flex API forum and not the Flex Viewer forum (as you should be), you have to be specific that you are speaking of the Flex Viewer Application. The Flex Viewer app will scale the map to what ever screen resolution that you are on automatically, unless you have manipulated the code and broke that capability. Do you have a screenshot of the map not scaling to full monitor width and height? Did you change the source code some where that could have broken this?
All Flex Viewer questions should be posted here:
http://forums.arcgis.com/forums/111-ArcGIS-Viewer-for-Flex
Andrew,
   Pardon me jumping in.
