Sample viewer ServiceAreaWidget projected results?
1013
04-05-2010 10:42 AM
SpencerLace
I am trying to get the Service Area widget in the sample viewer 1.3 to return a graphic that is already projected to state plane to match my basemap.  Currently, the widget locates a point on the map and computes the service area, but the result is in a different coordinate system than the point submitted. Does anyone have any ideas what I can do to force the result geometry and/or graphic to be my (map.spatialReference.wkid), or to have geometryService.project() the result of service area?
Spencer
PrashanthSukumaran
Hi Spencer,
The ServiceAreaWidget uses the Geoprocessor to retrieve the drive time polygon.  You have to pass the output spatial reference (outSR).
var params:Object =
                      "Input_Location": featureSet,
                      "Drive_Times": driveTimes,
                      "env:outSR": 3566,
                                    "env:processSR": 4326 // Input spatial reference
Thanks
Prashanth Sukumaran
SpencerLace
Yes!  Thank you, this change made it work.
