Sample NAnt build script
1852
10-12-2010 09:36 AM
BradleyJanke
Here is a sample NAnt build script for your flex projects.  I have this building a project that has the ESRI Flex API in it so it should be a simple installation.  I will explain to make it easier.
Here is the script
<?xml version="1.0"?>
  <project name="FV2" default="build" basedir=".">
    <target name="build">
  <echo message=""/>
  <exec program="C:\Program Files\Adobe\Adobe Flash Builder 4\sdks\4.0.0\bin\mxmlc.exe" basedir="${project::get-base-directory()}\src">
  <arg value="${project::get-base-directory()}\src\index.mxml"/>
  <arg value="-library-path+=${project::get-base-directory()}\libs\agslib-2.1-2010-09-17.swc" />
  <arg value="-locale=en_US" />
  <arg value="-source-path=locale/en_US" />
  <arg value="-keep-all-type-selectors=true" />
  </exec>
    </target>
  </project>
Change the path in this line to reflect your environment
This line assumes your ESRI Flex swc is in the lib folder of your project.  If it is not.... change it accordingly
Change these if you need to... should be self explanatory
Specifying the locale folder is used for finding ViewerStrings.properties file.
Resources that may be of assistance:
  • Unable to Resolve errors - You may run into a ton of reference errors.  The compiler may have trouble finding the assets folder.  Try this.  I added the '/' to the beginning of the paths and then found this URL that solidified other people were doing the same.
If you run into problems let me know....
Edit:
Also... if you are interested in localizing flex applications with Ant (non NAnt) then try this link... Seems handy...
