Run error on Flexviewer Project
1725
08-04-2010 09:41 AM
PeteVitt
I just installed Adobe Flashplayer 4, imported the flexviewer project and built it as described in the documentation and set my output directory to a valid location on my server in the wwwroot directory.  When I go to run the index.html I get the following error:
Error: Event Target: [object HTTPOperation]
Event Type: fault
Fault Code: Server.Error.Request
Fault Info: HTTP request error
What do I need to do to correct this error and get the project to run
Thanks
Pete
DasaPaddock
Can you try a tool like HttpFox or Firebug to see what HTTP requests are being sent and which ones are failing?
MLowry
What method are you using to run the index.html?
PeteVitt
I am using the run button on the menu and also right clicking the index.mxml
PeteVitt
the error pops up when it moves to the document.write below
<script type="text/javascript">
                var pageHost = ((document.location.protocol == "https:") ? "https://" : "http://");
                document.write("<a href='http://www.adobe.com/go/getflashplayer'><img src='"
                                + pageHost + "www.adobe.com/images/shared/download_buttons/get_flash_player.gif' alt='Get Adobe Flash player' /></a>" );
            </script>
any idea?
Thanks
PeteVitt
I rebuilt the project again and it worked --
