RPC Fault faultString when trying to use database in layer
3848
03-30-2011 08:18 AM
DaviKucharski
Hello. I have the following code that works on a layer that has a data source of the database/table. I get the following error on the queryTask.Execute if the red line highlighted is used. I get no errors and the correct results if I use the line highlighted in Blue. It must have something to do with permissions or the userid/password the system is trying to use to select from. The layer itself comes up, just the Query fails. I do know that the column ID_ exists and the layer has the Query option checked on.
[RPC Fault faultString="Unable to complete operation." faultCode="400" faultDetail="Unable to complete Query operation."]
code
var queryTask:QueryTask = new QueryTask("http://dg2k8esridev1/ArcGISDevelopment/rest/services/ZipCodesDemographics_FromFile/MapServer/2");
var query:Query = new Query();
query.where = "ID_ = '60462'";
query.where = "ID_ in (select distinct zip_code from dg2k3sqltest1.reference.dbo.ref_zip_codes where ref_sources_id = 25)";
query.outSpatialReference = map.spatialReference;
query.returnGeometry = true;
query.outFields = [ "ID_" ];
queryTask.execute(query, new AsyncResponder(onResult, onFault));
RobertScheitlin__GISP
Davi,
   Sub-queries inside a Where clause are not supported by the queryTask.
Any valid SQL where clause operating on the fields in the layer is allowed
http://help.arcgis.com/en/webapi/flex/apiref/com/esri/ags/tasks/supportClasses/Query.html
DaviKucharski
Robert,
First, thank you for your response. I am new to the ArcGIS API for Flex. If the query and queryTask will not allow me to join against another database table, do you know of a way for me to do this.
My example is my Layer is of all Zip Codes (33,000 records somewhat). When I drill down into an area I want to only highlight the zip codes that the client has requested. This could be a large list of zip codes so I am holding them in a temp table on my database. I don't see passing a list on the querystring as acceptable. I was hoping to somehow use the layer and temp table to highlight only the zip codes in the temp table. This was available in ArcIMS.
Davi,
   As sub-queries are not supported. The only way I see to do this is with two query tasks as long as ref_zip_codes is a registered standalone table in a geodatabase and you are using ArcGIS Server 10 you can run the sub-query first to get the values for the second query (which is what you said you don't see as acceptable).
DaviKucharski
Robert,
But I thought a queryTask was used with a Map Resource to query a Layer. This table would be a table of data. I didn't think you could use the queryTask for that. I do see where you are going with the theory of populate 1 queryTask and then use that queryTask as a part of the 2nd queryTask. I just don't see how you would populate the 1st queryTask with something like 'select zip_code from tmp_zipcodes_123456'. Again this temp table would be valid for 1 user and another user would have the temp table of 'select zip_code from tmp_zipcodes_987654'. They would be valid tables in the database but would have no service associated to them because of their availability.
Davi,
   In ArcGIS Server 10 standalone tables can now be queried if they are part of and registered with a geodatabase. But in your case a temp table will be neither so this is not going to work for you.
