Routing Layer not showing
845
08-14-2011 12:41 PM
AzizulAlam1
I am new at ArcGIS flex API. I want to do a basic route task. I have created a route network using network analyst. In ArcMap it is working fine. I have merged all road layer into one layer. It is a very simple polyline data. It has no time, barrier, u-turns or historical traffics data. I have published it into ArcGIS Server with network access. Now when I am changing the rest endpoint in Basic Routing Code of Flex it is not showing the Routing Layer in Browser. When I am clicking for 2 stops it attaching the triangle marker and it is calculating Route (Its showing the busy cursor tool for a long time if I click 2 stop to a far distance or its taking a little time if i click near to each other). I am giving the Coding...
I am attaching the Route and street files. Please help me to learn this Topic.
 <?xml version="1.0" encoding="utf-8"?>
<s:Application xmlns:fx="http://ns.adobe.com/mxml/2009"
               xmlns:s="library://ns.adobe.com/flex/spark"
               xmlns:esri="http://www.esri.com/2008/ags"
               pageTitle="Routing with the ArcGIS API for Flex">
    <s:layout>
        <s:VerticalLayout paddingTop="10"/>
    </s:layout>
    <fx:Script>
        <![CDATA[
            import com.esri.ags.FeatureSet;
            import com.esri.ags.Graphic;
            import com.esri.ags.events.MapMouseEvent;
            import com.esri.ags.events.RouteEvent;
            import com.esri.ags.tasks.supportClasses.RouteResult;
            import com.esri.ags.utils.WebMercatorUtil;
            import mx.controls.Alert;
            import mx.rpc.events.FaultEvent;
            private var lastRoute:Graphic;
            private function mapClickHandler(event:MapMouseEvent):void
                var stop:Graphic = new Graphic(event.mapPoint, stopSymbol);
                graphicsLayer.add(stop);
                stops.push(stop);
                if (stops.length > 1)
                    routeTask.solve(routeParams);
            private function solveCompleteHandler(event:RouteEvent):void
                var routeResult:RouteResult = event.routeSolveResult.routeResults[0];
                routeResult.route.symbol = routeSymbol;
                graphicsLayer.remove(lastRoute);
                // TODO: if your server is AGS10, you can ask for it to be projected
                // (instead of having to project it clientside)
                routeResult.route.geometry = WebMercatorUtil.geographicToWebMercator(routeResult.route.geometry);
                lastRoute = routeResult.route;
                lastRoute.toolTip = routeResult.routeName;
                if (routeResult.stops && routeResult.stops.length > 0)
                    lastRoute.toolTip += " with " + routeResult.stops.length + "stops";
                if (routeResult.route.attributes.Total_Time)
                    lastRoute.toolTip += " in " + Math.round(Number(routeResult.route.attributes.Total_Time)) + " minutes.";
                graphicsLayer.add(lastRoute);
            private function faultHandler(event:FaultEvent):void
                Alert.show(event.fault.faultString + "\n\n" + event.fault.faultDetail, "Routing Error " + event.fault.faultCode);
                // remove last stop (or both stops if only two)
                if (stops.features.length <= 2)
                    graphicsLayer.clear();
                else
                    graphicsLayer.remove(stops.features.pop());
    </fx:Script>
    <fx:Declarations>
        <esri:RouteTask id="routeTask"
                        concurrency="last"
                        fault="faultHandler(event)"
                        requestTimeout="30"
                        showBusyCursor="true"
                        solveComplete="solveCompleteHandler(event)"
                        url="http://pioneer/ArcGIS/rest/services/DhakaRouteNew/NAServer/Route"/>
        <esri:RouteParameters id="routeParams">
            <esri:stops>
                <esri:FeatureSet>
                    <esri:features>
                        <fx:Array id="stops"/>
                    </esri:features>
                </esri:FeatureSet>
            </esri:stops>
        </esri:RouteParameters>
        <esri:SimpleMarkerSymbol id="stopSymbol"
                                 size="15"
                                 style="triangle">
            <esri:SimpleLineSymbol width="4"/>
        </esri:SimpleMarkerSymbol>
        <esri:SimpleLineSymbol id="routeSymbol"
                               width="10"
                               alpha="0.5"
                               color="0x0000FF"/>
    </fx:Declarations>
    <s:Label fontSize="12" text="Click on the map to add stops for your routing..."/>
    <esri:Map mapClick="mapClickHandler(event)" openHandCursorVisible="false">
  <esri:ArcGISDynamicMapServiceLayer url="http://pioneer/ArcGIS/rest/services/DhakaRouteNew/MapServer"/>
        <esri:GraphicsLayer id="graphicsLayer"/>
    </esri:Map>
</s:Application>
baixuehong
I have the same problem with you, and it has puzzle me for several days. Wish there is somebody to help us...:(
