RouteTask Stops
1246
10-14-2010 01:30 PM
CaseyBentz
Hey All,
I am trying to change the name of a stop from Location 1 to something meaningful from an attribute of the graphic that is being used as a stop.  I am not sure how to do this. Does anyone know how to do this?  Any help would be greatly appreciated.
Casey
DasaPaddock
Try setting an attribute on the stop called "Name".
See example at:
http://help.arcgis.com/EN/arcgisserver/10.0/apis/rest/nasolve.html
CaseyBentz
Dasa,
I have included my code.  I have tried to assign the .name property of g1, with no success.  Do you have any suggestions on how to do this in Flex?
Casey Bentz
[Bindable]
private var stops:FeatureSet = new FeatureSet([]);
 private function routeOrders():void{
  stops = new FeatureSet([]);
  var start:Graphic = new Graphic(WebMercatorUtil.geographicToWebMercator(new MapPoint(Model.instance.activeVehicle.attributes.StartX,Model.instance.activeVehicle.attributes.StartY, Model.instance.map.spatialReference)), new TextSymbol('Start',null,0x000000,false,0,true,0xFFFFFF,'middle',0,20,20));
  Model.instance.oLayer.add(start);
  stops.features.push(start);
  for each(var order:Graphic in Model.instance.oLayer.graphicProvider){
    var g1:Graphic = new Graphic(MapPoint(order.geometry));
    stops.features.push(g1);
   var end:Graphic = new Graphic(WebMercatorUtil.geographicToWebMercator(new MapPoint(Model.instance.activeVehicle.attributes.EndX,Model.instance.activeVehicle.attributes.EndY, Model.instance.map.spatialReference)), new TextSymbol('End',null,0x000000,false,0,true,0xFFFFFF,'middle',0,20,20));
   Model.instance.oLayer.add(end);
   stops.features.push(end);
   if (stops.features.length > 1){
     routeTask.solve(routeParams);
<esri:RouteTask id="routeTask"
        concurrency="last"
        fault="faultHandler(event)"
        requestTimeout="30"
        showBusyCursor="true"
        solveComplete="solveCompleteHandler(event)"
        url="http://tasks.arcgisonline.com/ArcGIS/rest/services/NetworkAnalysis/ESRI_Route_NA/NAServer/Route"/>
    <esri:RouteParameters id="routeParams" stops="{stops}" outSpatialReference="{Model.instance.map.spatialReference}"
     findBestSequence="true" returnStops="true" preserveFirstStop="true" preserveLastStop="true"/>
CaseyBentz
I figured it out. I was looking past the obvious. That is my usual path.
[LEFT] stops = new FeatureSet([]);
 var start:Graphic = new Graphic(WebMercatorUtil.geographicToWebMercator(new MapPoint(Model.instance.activeVehicle.attributes.StartX,Model.instance.activeVehicle.attributes.StartY, Model.instance.map.spatialReference)), new TextSymbol('Start',null,0x000000,false,0,true,0xFFFFFF,TextSymbol.PLACEMENT_START,0,20,20));
 start.attributes = {Name: "Start"};
 foreach(var order:Graphic in Model.instance.oLayer.graphicProvider){
   g1.attributes = {Name: order.attributes.OrderNum};
 var end:Graphic = new Graphic(WebMercatorUtil.geographicToWebMercator(new MapPoint(Model.instance.activeVehicle.attributes.EndX,Model.instance.activeVehicle.attributes.EndY, Model.instance.map.spatialReference)), new TextSymbol('End',null,0x000000,false,0,true,0xFFFFFF,TextSymbol.PLACEMENT_END,0,-20,20));
 end.attributes = {Name: "End"};
}[/LEFT]
