Retrieving Map Resolution
959
03-01-2011 10:10 AM
JasonLevine
Is there any way to get at the map resolution through the API?
For my tiled service, I have:
Level ID: 9 [Start Tile, End Tile]
      Resolution: 3.91839297309028
      Scale: 4513.988705
To get at the scale, I would use: map.Scale
How would I get at the resolution? I need to capture it for some calculations.
Jason
DasaPaddock
You can use map.level as the index to the map.lods Array and then get the resolution from the corresponding LOD.
Reference:
http://help.arcgis.com/en/webapi/flex/apiref/com/esri/ags/Map.html#lods
JasonLevine
Thank you, I forgot this was stored in the array.
-Jason
