resultGraphic attribute Assignment
1130
01-24-2012 05:01 PM
ShaunWeston
I'm trying to setup a configuration xml file for a user to set the field names in, which would then be picked up by the mxml script.
Basically I have a bunch of code like this:
var Ratepayer1LastName:String = resultGraphic.attributes.Ratepayer1LastName;
var Ratepayer2FirstName:String = resultGraphic.attributes.Ratepayer2FirstName;
And I want that last bit to be set by the user in an xml file. So I basically want this bit to always stay the same - "resultGraphic.attributes." and then the last bit (e.g. Ratepayer1LastName) to be assigned from an xml file.
I'm not sure how to do this? If I go:
userconfig = configXML.windowtitle
var Ratepayer1LastName:String = "resultGraphic.attributes." + userconfig;
it obviously just takes that string and not the actual attribute value.
I've got myself a bit confused.
RobertScheitlin__GISP
Shaun,
   You should be able to do this:
userconfig = configXML.windowtitle var Ratepayer1LastName:String = resultGraphic.attributes[userconfig];
Don't forget to click the top arrow (promote) and to click the Mark as answer check as shown below:
Shaun,
ShaunWeston
Awesome thanks that's what I'm after. You have saved me a lot of time trying to figure that out when it was quite easy.
