RestLegend ArcGis 9.3 FlexViewer 1.3
2973
11-16-2010 01:31 AM
NicolaLugeri
Hi all,
I'm sorry, but I got lost in the story of the restlegend "tool".
I've downloaded and tried to run the first version (restLegend.zip), but I cannot have it working because -I guess- the instructions refer to the livemapswidget stored under \....\esri\solution\flexviewer\widgets\ while the viewer loads this widget from \....\esri\solution\esa\widgets\  which has a significantly different code.
I've come across a restLegend4.zip, which is a version for ArcGis 10.
I was not able to find the "intermediate" versions, nor other users having the same problems.
Any tips, please?
Thanks a lot
Nicola
NicolaLugeri
We solved the problem, basically we took the code blocks marked "legend work" from Robert's  livemapswidget.mxml and inserted them in that stored under the \esa\ directory.
Cheers!
RobertScheitlin__GISP
Nicola,
   Glad you got it working. Responding to this thread was on my to do list unfortunately that list is very long right now.
NicolaLugeri
Nicola,
Robert,
sorry for the delay and thanks for your reply, which keeps me hoping that other questions of mine are still in and will enter your "to do list"!
so bad that human cloning is not yet implemented (at least for "normal" purposes)
