REST Morning wake up
3788
13
08-06-2010 05:53 AM
andrewj_ca
I've read alot of posts regarding slow operation or errors accessing a rest service first thing in the morning or the first operation of the day.  I thought I'd attach a little application I use to prevent this.  It also has email notification for when a service stops and starts.  I figure it works for us and may work for you.  After using this app, please feel free to send me your comments or issues.  I've included two services in the list for an example.  Cheers.
Service List (xml)
Web Service Monitor Executable (exe)
RobertScheitlin__GISP
mcnaughty79,
   Can you also provide the source for the web service monitor app?
andrewj_ca
Unfortunately I won't be able to legally share the source code but I am willing to help with any questions you may have.  Cheers
mcnaughty79,
  Shame... I just can't run an executable from an unknown party when I can not verify the code is doing only what it claims to do.
andrewj_ca
Would a snippet of the code suffice or do you require the complete source? I guarantee there is nothing malicious in the executable.
CaseyBentz
Robert,
I have an application that runs as a scheduled task that basically parses my /ArcGIS/rest/services directory and opens each service.  I wrote it a while ago, with no documentation, so take it as it is.
I have attached a zip file, which I have had no luck with attaching, so I have also include the source code that you could copy into a console appliction.
Imports System.Threading
Imports System.Net
Module agsServicesWakeUp
    Sub Main()
        readHTML()
    End Sub
    Private Sub readHTML()
        Try
            Dim objWebClient As New WebClient
            objWebClient.UseDefaultCredentials = True
            Dim aRequestHTML() As Byte = objWebClient.DownloadData("http://yourservername/ArcGIS/rest/services") 'Change to your server
            Dim counter As Integer = 0
            Dim html As String = ""
            Do While counter < aRequestHTML.Length
                html += Chr(aRequestHTML.GetValue(counter))
                counter = counter + 1
            Loop
            Dim serviceFolderArray() As Object = {}
            Dim i As Integer = 0
            Dim j As Integer = 1
            Dim count As Integer = 0
            Do While i < html.Length
                i = InStr(j, html, "/ArcGIS/rest/services/")
                If i > 0 Then
                    j = InStr(i, html, ">") - 1
                    Dim serviceFolder() As String = {html.Substring(i - 1, j - i)}
                    Array.Resize(serviceFolderArray, count + 1)
                    Array.ConstrainedCopy(serviceFolder, 0, serviceFolderArray, count, 1)
                    count = count + 1
                    i = j
                Else
                    i = 0
                    j = 1
                    count = 0
                    Exit Do
                End If
            Loop
            Dim k As Integer = 0
            Dim servicesArray() As Object = {}
            Do While k < serviceFolderArray.Length
                Dim serviceRequestHTML() As Byte = objWebClient.DownloadData("http://yourservername" + serviceFolderArray(k).ToString) 'Change to your server name
                counter = 0
                html = ""
                Do While counter < serviceRequestHTML.Length
                    html += Chr(serviceRequestHTML.GetValue(counter))
                Loop
                    i = InStr(j, html, serviceFolderArray(k).ToString + "/")
                    If i > 0 Then
                        Dim service() As String = {html.Substring(i - 1, j - i)}
                        Array.Resize(servicesArray, count + 1)
                        Array.ConstrainedCopy(service, 0, servicesArray, count, 1)
                        count = count + 1
                        i = j
                    Else
                        i = 0
                        j = 1
                        Exit Do
                    End If
                Loop
                k += 1
            Loop
            callURL(servicesArray)
        Catch ex As Exception
            MsgBox(ex.Message)
        End Try
    End Sub
    Private Sub callURL(ByVal servicesArray As Object, Optional ByVal sleep As Integer = 100)
        Dim webApp
        webApp = CreateObject("InternetExplorer.Application")
        webApp.Visible = False
        Do While i < servicesArray.Length
            Console.WriteLine("http://yourservername" + servicesArray(i).ToString) 'Change to your server name
            webApp.Navigate("http://yourservername" + servicesArray(i).ToString) 'Change to your server name
            Thread.Sleep(sleep)
            i += 1
        Loop
        webApp.quit()
        webApp = Nothing
    End Sub
End Module
andrewj_ca
Quick snippet:
    Public Function PingWebService(ByVal serviceURL As String, ByVal sType As String) As Boolean
        Try
            Dim httpreq As Net.HttpWebRequest = Net.WebRequest.Create(serviceURL)
            Dim httpres As Net.HttpWebResponse = httpreq.GetResponse()
            Dim httpr As Boolean = False
            If httpreq.HaveResponse = True AndAlso Not (httpres Is Nothing) Then
                Dim r As New IO.StreamReader(httpres.GetResponseStream())
                Dim str As String = r.ReadToEnd
                Select Case sType
                    Case "REST"
                        If Not str.IndexOf("<div class=" & Chr(34) & "restErrors" & Chr(34) & ">", 0) > -1 Then
                            httpr = True
                        End If
                    Case "WMS"
                End Select
            End If
            Return httpr
            Return False
        End Try
    End Function
Use:
PingWebService("http://server.arcgisonline.com/ArcGIS/rest/services/World_Imagery/MapServer","REST")
Return true or false
Andrew and Casey,
   Thanks for the code. I believe that this is a mute point with ArcGIS Server 10 though. In 10 the ArcGIS SOC Monitor (that didn't do anything in 9.3) handles keeping the service awake.
andrewj_ca
No problem Robert, but lets be honest.  No topic is ever mute when it comes to ArcGIS.
Andrew,
  Good point. Yours and Casey's code will help all of those that will not be upgrading to 10 right away.
