Resize Popup for Identify Widget
3004
11-30-2010 03:59 PM
jaymepeltz1
I have added a image to Roberts Identify 2.1.7 widget which appears in the results, how do I change the size of the popup so you can see the Image more clearly.
Cheers
Jayme
RobertScheitlin__GISP
Jayme,
In the InfoPopupWidget.mxml the:
<s:Group id="infoCanvas"
             width="210"
             minHeight="30">
controls the size of the image.
jaymepeltz1
Thanks Robert worked great,
Just another query is there anyway that you can move the popup widget around map when it is displayed.
Thanks for your help
Jayme
Jayme,
   Nope, if you want to move the popup around then you will have to create a custom infowindow using a titlewindow.
JamesEdge
Robert
How do you make the popup window open to the left of the identify point instead of the right?
