Require help with Flex Viewer 2.0
724
09-10-2010 11:55 AM
SantoshSeshadri
Good Afternoon ESRI Flex API Team,
                                I have been working with the flex 2.0 api and the editor widget that comes with it. I am aware that there is no undo function as of yet. But is there a way I can prevent users from editing vertices? I just want them to be able to cut, merge and edit attributes of a polygon(s). Also, where exactly do you edit the EditTool class. I am not able to find the classes for the api.
Any suggestions will be greatly helpfull!!
Thank you
Santosh
