RequestTimeout of RouteTask
2574
09-18-2014 12:30 AM
FarhanQayum
what is the maximum value for RequestTimeout of RouteTask to support?
If I increase the RequestTimeOut for  240 seconds,long route will be found otherwise not so my question is what is the maximum limit i can put to process the request successfully or it has some maximum limit already defined?
RobertScheitlin__GISP
Farhan,
   Straight from the documentation:
requestTimeout property
requestTimeout:int
The request timeout in seconds. A value less than or equal to zero prevents request timeout.
The default value is -1.
This property can be used as the source for data binding.
com.esri.ags.tasks.RouteTask
