Reproject point on grahics layer
1026
06-22-2012 08:48 AM
RaoBase
All my datasets are currently in British National Grid.
I have received a new dataset with Longitude and Latitude.
I would like to query this layer and display the points on a graphics layer.
However the points appear in the wrong location on the map.
for each (var graphic:Graphic in featureSet.features)
  graphic.geometry.spatialReference = map.spatialReference
  graphicsLayer.add(graphic);
Any ideas?
ShaunWeston
So what format is the dataset in?
I think you would have to re-project those points using a geometry service there is a sample here - http://resources.arcgis.com/en/help/flex-api/samples/index.html#/Project_a_point/01nq0000004w000000/
o you would get the coordinates of the graphic, send them to the geometry service to re-project and then draw the coordinates that are returned.
